going from standard ign. switch to toggle switches
i was wondering if anyone has converted their standard ign. switch to toggle switches and push button starter? i need help in wiring up toggle switches for ignition, fuel pumps, aux. fan, and adding kill switch to turn off everything including altenator. diagrams or thoughts would be greatly appreciated.
+1--I'd be interested too.
You might take a look at this site from member 911pcars
http://members.rennlist.org/911pcars/RemoteStarter.htm |
I did it. You need a wiring diagram for your year, available here.
http://forums.pelicanparts.com/uploa...1247355877.jpg Check the load carrying capacity of your push-button start before hooking it up. I used a relay so very little current goes through the switch itself. |
I currently (unintentionally) have a push-button starter in my car. My ignition switch recently failed for a second time in that the tumbler isn't making the contact in the final position to engage the starter motor. So I pulled the piece off the back of the ignition switch, found which two pins engage the starter (by trial and error - make sure the car is in neutral!) and ran 2 wires out of it, into a generic normally-open push-button switch. Found it at Canadian Tire for about $5 - they had all sorts of different ones. It works absolutely perfectly, in fact so well that I won't bother fixing the ignition switch until the car goes away for the winter.
You can wire everything through the back of the ignition switch with just a little trial and error. The hard part will be fabricating and installing a panel with the correct switches that looks nice. |
thanks for the info. anyone else have ay pics or diagrams of their ignition switch delete?
| All times are GMT -8. The time now is 01:01 AM. |
