Terminal Repair Kit
I'm embarrassed to even post this question, but I'm going to break this part if I continue on my current route. Does anybody the how to remove the terminals of this part from it's harness-
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=1-287-013-003-M14
Typically there is a prong that you can push down on one side with a small screwdriver, then slide out, but that's not working.
1982 911SC Targa
Old 09-10-2009, 07:12 AM
The terminals have a prong that you need to push with a jeweller screwdriver from the front of the connector.
I can post a picture later if you still cannot separate de terminal from the connector.
Old 09-10-2009, 12:12 PM
Here is a picture of one of those terminals.
You can see the prong that you need to push so you can pull it out of the connector.
Old 09-10-2009, 08:29 PM
