-   -   Need some info on oilcooler mod for 3.6 conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/497940-need-some-info-oilcooler-mod-3-6-conversion.html)
matty74 09-10-2009 01:49 PM
Need some info on oilcooler mod for 3.6 conversion, is there a kit or a tutorial on doing this?
Cheers
Matt
midnight911 09-10-2009 02:10 PM
i have mocal 44 rows from steve timmins. his website has more details. the kit is adding another oil cooler inside driver side fender, in place of window washer tank and fuel evap tank. there are tons of examples you'd run into in this forum...mine also buried some where...
matty74 09-10-2009 02:17 PM
Already have the front fender, I may consider another on the left side, I want to the on-engine conversion so I run one on the engine and one up the front
midnight911 09-10-2009 03:39 PM
I remember Jack Olson comment that that's an expensive proposition...sounds like fair amount of engineering necessary. much cleaner, economical, and effective going to the front...I understand. anyways, you can search for those comments made on the subject.
