rennshift install, anyone need to see this?
Just purchased a rennshift shifter, anyone need the play by play of the install? (with pics) Straight forward I think, let me know, it's on the way from rennsport...
I installed a Rennshifter in my 73 teener. That 901 transmission shifted better than when it was new! High quality product and a very easy install. Make sure you replace all the bushings in the linkage for the best results.
I would install one in my SC but the 915 transmission was expertly rebuilt and shifts like new. "if it ain't broke don't fix it". |
The rennshift swap is easy..
Right now I'm trying to adjust the coupler, and Jb responded to my thread that using a bugee cord to hold it far left works great. I guess you could add that as well? |
Everybody loves pics, so I say go for it. This is a technical forum after all. Thanks in advance for your input.
in 1979 I wanted to buy a new sports car so I drove a 1975 914 with only 2000 miles on it, a new MGB and a 124 Fiat Spider. I didn't buy the teener because of the long throw of the shifter and it didn't feel crisp. I ended up buying the spider which turned out to be a fantastic car.
I sold the spider in 1983 to buy a 1959 356A. Even with the funky shifting of the 356 (I wish the rennshifter was around in 1983!) it changed my chemistry and I have never looked back.:) |
Go for it, I would love to see how your install goes compared to mine. I installed one and had quite a bit of trouble at first getting it adjusted. I could only get it to go into either 1,2,3,4 (no 5th or reverse), or 3,4,5,R (no 1,2). It turned out to be bad bushings in the shift coupler. I replaced that with a Stomski Racing Precision Shift Coupler and it cured everything. It seems that the Rennshift needs a very tight bushings to be able to adjust properly. Well worth the effort though, because the difference in shifting is amazing.
Just read my post again and I have to start proof reading before I post while at work. |
What the Duck? where are the purty pictures :D
Can I assume you have a 915 transmission? My current shifter is bolted underneath the carpet, so do I just slide the shifter under from the side of the carpeting and bolt it down? I checked out the two pics of your car. VERY NICE! More pics of your car..Thanks for your help too. |
| All times are GMT -8. The time now is 07:16 AM. |
