Cam choice for awakening 2.2T
Hello folks,
In the process of rebuilding a 2.2T with a friend, our cam grinder made us 2 proposition as follow:
Values are given @ 1mm (0.04") lift and 0 lash
Rocker ratio 1.50 (some doubt on that one)
Option 1:
Duration 232/224, lift: 6.75/6.00mm @cam, 10.05/8.94 @valve (0.256/0.236" - 0.396/0.352")
Option 2:
Duration 242/232, lift: 7.35/6.60mm @cam, 10.95/9.38 @valve (0.289/0.260" - 0.431/0.369").
Engine will get 86mm biral cylinders and JE pistons at the same time.
What do you guys think about these values?
Lift looks a bit small compared to duration but I don't have a deep knowledge on 911 cams.
Cheers
Arnaud
Old 08-02-2017, 08:00 AM
Arnaud, the Solex cam has been consistently recommended for your setup. I don't recall the specs, but you should be able to find them quite readily and compare them to your options.
Regards,
dho
Old 08-02-2017, 05:06 PM
T77911S's Avatar
CR is big factor in deteriming what cam to use.
you can "over cam" a low compression engine.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-03-2017, 04:23 AM
CR should be around 10.1 to 1
Here's what Dougherty list for the Solex and others:
Model-------------------------Duration @ 1mm-------@ .050"--------Valve lift-------Lobe seperation angle----Lift @ overlap setting
Porsche 911 Solex--I/E------248/236-----------------242/230-------.455"/.414-----97--------------------------4.2-4.6 mm
Porsche 911 E-------I/E------238/226-----------------230/222-------.405"/.393"----102-------------------------3.0-3.3 mm
Low proposed lift is maybe due to the original T cams available "meat"...
Thanks for your input
Old 08-03-2017, 05:27 AM
Home of the Whopper
E or solex cams.
2.4 crank and rods.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 08-03-2017, 06:09 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
DC 30's (mod S) on my 73 E with 10.0/1 CR was awesome and a highly recommended setup. Higher performance cams will have more overlap to help the engine breath. This lowers the compression to some degree (in exchange for volumetric efficiency). This needs to be offset by higher compression pistons (which you have).
Real world experience, the car hit a power-band at 6k RPM'S where it used to run out of breath with the stock E cams.
Old 08-04-2017, 08:50 AM
Thanks for all the feedback, the point is that our configuration is more or less fixed with the cost in mind:
- original crank
- 86mm cylinders (as original ones are scored)
- slightly ported heads
- dansk heat exchanger
- reground T cams
Here's the proposition from our local cam grinder (in France):
After checking details of different data from well known cam grinders, I think that the intake will be fine but maybe it would better to shorten exhaust duration in order to increase the lift.
What do you think?
Old 08-08-2017, 12:11 AM
SWS911's Avatar
I think with that C/R you should twin plug, and running high RPMs you need a counter balanced crank.
Old 08-08-2017, 05:50 AM
