Help me id this transmission
needing help identifying the transmission in a 72 targa got 2 number 9153032210R is on the bottom of the case and 91530101 is on the side of the case. What transmission is this and how much hp can it handle approx?
Matt |
gearhead
There's a rib on the bottom of the case that contains the type number and serial number stamped into it. It will be something like 915/02 or 915/12 then followed by something with the format of 7x xxxxx where 'x' is variable. Post that information and we can help you more. Or pictures.
What you have posted so far as just casting numbers and don't reveal much.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
