JDawg
AC belt removal
Is there an issue w/ just removing the AC belt off of the compressor. I never use it & wonder if it would have a positive effect on gas mileage or performance.
1983 911 SC Targa (sold) 2007 BMW 335i 2005 F150 Lariat |
no problem removing the belt. Not sure it will improve performance or milage as it was just rotating the pulley and not engaging the compressor.
Tony G 2000 Boxster S |
no issue removing belt by no noticeable gain in performance or mpg
Detached Member
I'd leave it on, if it works, you should run it once a month to keep the seals lubricated. If you ever sell, it will add to resale value. Just spinning the magnetic clutch probably doesn't take even 1/100th of 1 HP.
Hugh |
