springerman55's Avatar
E10 fuel pros/cons...
I live in Austin, TX and drive a slightly modified '83 SC. We have been informed by the media recently that E10 fuel will begin distribution here within the next few weeks. I have been on other forums and the consensus is that E10 can be bad for older vehicles (if not driven very regularly). I also own a classic Chevrolet and Harley Davidson so this E10 fuel will effect those as well. I see that Sta-Bil has a marine product additive for ethanol based fuels. Any experience or comments on E10 fuel and whether it is safe to run in the Porsche CIS fuel system? Thanks in advance...
Old 09-15-2009, 10:41 PM
beepbeep's Avatar
more octane (if not blended with low octane gasoline)
Engine goes slightly leaner if not equipped with lambda (but it's usually OK)
Thank you for your time,
Old 09-15-2009, 11:12 PM
GothingNC's Avatar
Keep a spare fuel filter handy in case the E-10 pulls the rust and dirt from the tank and lines.
I had a hot start problem for a while after getting a tank of gas with E-10 and it took a few tanks of regular UL and Techron to get back to normal.
Effects of Ethanol in gas
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 09-16-2009, 03:40 AM
Designer King
Paulporsche's Avatar
Current thinking seems to be that you will be OK w/ CIS if your fuel is less than 15% ethanol. I've used a 10% blend (Sunoco 94 Gold here) for at least 15 years. The only CIS problem I had was recently, and it was almost certainly not fuel related.
You might see a drop in your fuel mileage by about 10%. It would be interesting if you keep track of that and let us know.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-16-2009, 05:11 AM
Recreational User
porschenut's Avatar
We've been using state-mandated E10 here in Colorado for about 2 decades. The manual says up to 10% ethanol is safe.
Old 09-16-2009, 06:03 AM
brads911sc's Avatar
We have had it for years in Houtson. No issues. I run Chevron Permium only...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 09-16-2009, 08:49 AM
There's never been anything else in my SC since I rebuilt it about five years ago--E10 is mandated in New York. (I have PMOs and a fuel cell.)
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-16-2009, 09:15 AM
Son of a Son of a Sailor
Looking_for_911's Avatar
Recently I shot a BassMasters fishing tournament where the Sta-Bil folks had a display set up and I asked the rep about using it in my SC. He told me that it really only helps if you are storing the car, like over the Winter..... seemed odd to me, but that's what the man said.
"Living and Dying in 3/4 Time"
Old 09-16-2009, 11:40 AM
Well, that's what it's for. It stabilizes the fuel, as the name says--doesn't allow it to deteriorate. It doesn't make it better, or higher-octane or anything. I use it in chainsaws, lawnmowers and snow-throwers.
Stephan Wilkinson
Old 09-16-2009, 12:21 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
pros= will help clean out the gunk in your fuel tank
cons= all that gunk gets in your fuel system
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 09-16-2009, 01:57 PM
Sta-Bil will clean out the gunk in your fuel tank??? That's a claim I've never heard.
Stephan Wilkinson
Old 09-16-2009, 02:02 PM
JBO JBO is offline
The marine stabil, which is blue, is different than the red version, and is said to be beneficial in counteracting the negative effects of ethanol in fuel. It is an additive for regular use and not specifically for storage like the red stuff. It is about 3 times more expensive than the red stuff. I just got some at Pep Boys, but have not used it yet.
Old 09-16-2009, 02:07 PM
teenerted1's Avatar
not the sta-bil....the ethanol is what will break down the gunk in your system
sta-bil good e10 bad
Ted
Old 09-16-2009, 02:48 PM
Originally Posted by JBO View Post
......is said to be beneficial in counteracting the negative effects of ethanol........
Not to hijack this, BUT,... do you suppose this would work for people???????????
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-16-2009, 03:20 PM
HarryD's Avatar
It is my understanding that the Blue Marine Stabil has significantly more corrosion inhibitor which is why it is better for regular use in cars that run E10.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-16-2009, 03:22 PM
Recreational User
porschenut's Avatar
Curious....why is ethanol more harmful to CIS than other fuel delivery systems?
Old 09-16-2009, 04:56 PM
Two reasons:
1) Ethanol attacks elastomers (rubber) in the fuel system. Any rubber part in contact with the fuel thats not Viton suffers degradation and sooner or later, thats an expensive problem.
2) Ethanol is hygroscopic. Moisture absorbed by ethanol-laden fuel will corrode any ferrous parts in the fuel system and the Fuel Distributors are particularly vulnerable.
The constant use of Stabil will help forestall problems. Further, keep the tank full anytime the car is stored to minimize condensation.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-16-2009, 07:48 PM
Recreational User
porschenut's Avatar
Just to make sure I understand, as I'm not that familiar with the parts in a CIS car, you're saying that CIS has more of these rubber and ferrous parts, and that's why CIS is more vulnerable to ethanol than EFI, MFI and carbs?
Old 09-16-2009, 08:30 PM
Two reasons:
Perfect written.
We've had it for a decade in Sweden 5% during the winter.
A lot of people are converting to E85 since it's classified as enviromental friendly.
Eats and detoriates rubber, fuel lines.
The fuel pump plastics in my 1966 fuel pump embritteled.
Disolves a lot of old "gue"
No stories from here that CIS are more sensitive.
About rust I think they add inhibitors in Sweden.
But now new fuel lines and so on are resistant to Ethanol.
If its a CIS it must be a couple of years so it might be time to change fuellines clean gastank and so on anyway.
btw bio diesel contamination in regular diesel is a growing problem.
911 1966 untuched exept 2,2E MFI -70 engine
Old 09-17-2009, 08:52 AM
David's Avatar
I'd carefully inspect the fuel line and return line rubber parts at the fuel pump. These are very prone to failure in the older cars.
Old 09-17-2009, 10:19 AM
