where would I find
the two bolts / plastic caps that fit in engine lid at top of grille......the two holes in lid are for mounting a wiper I believe and I removed mine and have the two holes - should there be a chrome bolt or a plastic plug in the two holes and where would I look
hope this makes sense......for a 70 car thanks in advance paul |
well I found a temporary fix - I removed the rear wiper and replaced two holes with cycle brake domed nuts , the ones for brake calipers - fitted with small rubber grommet (all from cycle store) and it looks fine - the nuts could easily be sprayed satin black
mine look nearly identical to the one that is part of rear wiper assembly photo taken with iPhone so not hi res paul http://forums.pelicanparts.com/uploa...1253465860.jpg http://forums.pelicanparts.com/uploa...1253465881.jpg |
| All times are GMT -8. The time now is 09:22 AM. |
