-   -   Rear Sway Bar Console Reinforcement - Pics (http://forums.pelicanparts.com/porsche-911-technical-forum/500693-rear-sway-bar-console-reinforcement-pics.html)
Steve W 09-22-2009 10:14 AM
Thought you folks might find some use in pics of my recent reinforcement of the rear sway bar console:
1: before with undercoating and primer removed from weld areas
http://forums.pelicanparts.com/uploa...1253638829.jpg
2) two metric M8 x 1.25 coupler nuts held in place over the original nuts
http://forums.pelicanparts.com/uploa...1253638857.jpg
3) The butterfly brace cut from a thick piece of galvanized Simpson steel strap
http://forums.pelicanparts.com/uploa...1253638871.jpg
Welded and primed. The coupler nuts are also welded lengthwise to the butterfly brace eliminating the other cause of failure, OE nuts pulling out of the console.
http://forums.pelicanparts.com/uploa...1253638881.jpg
911st 09-22-2009 01:54 PM
Steve,
We don't need no WEVO's.
I did almost the same thing on a 72 I had years ago (2.8 twin plug-dizzy w minilites). I butterflied it and added a plate with two holes in it over the mounting surface.
I am wondering if we need anything more than a good butterfly brace?
Nice work!
jpnovak 09-22-2009 02:08 PM
I like the additional thread support.
