EMJ EMJ is offline
Super tight brake rotor bolts!
So I'm replacing my front brake rotors - car's up, wheel is off. Problem is the 2 super tight 19mm bolts holding the caliper in place. Put copious amounts of wd40 on each bolt, still won't budge. Double checked that I was going left to loosen the bolt after several minutes, still no luck. Put a mallet to the wrench, muscled it - won't budge still.
Any ideas? Don't have an impact gun but I'll consider getting one as I'm doing more DIY stuff these days and could use it. Recommendations for a good impact gun are appreciated.
Thanks!
Ed
88 911 Carrera Coupe
Old 09-23-2009, 07:30 AM
I had the same problem on the rear calipers of an 89 Carrera, had to take a portion of pipe, cut it to the longest length I could get to fit in the limited space and placed it over the handle of the socket ratchet and then put my weight behind it. Good luck, it will come off with enough pressure.
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 09-23-2009, 07:55 AM
aj88cab's Avatar
Don't be offended, but be sure you are turning them the correct direction. It is easy to get twisted around and be tighting them (ask me how I know). Other than that try using a long breaker bar to loosen them as Steve mentioned.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 09-23-2009, 07:59 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Agree with the other guys, will add that WD40 is relatively useless as a penetrating oil, get some Aero-Kroil or at least use PB-Blaster for that...
Gary R.
Old 09-23-2009, 08:45 AM
Hi
Targa Me's Avatar
Try smacking the head of the bolts with a hammer, sometimes this gars them loose. If you have a helper there with you, have some one smack the bolt as you try to turn it. Good luck.
Old 09-23-2009, 08:57 AM
EMJ EMJ is offline
Thanks for the suggestions, guys... I think aj88cab has a good point about ensuring I'm turning the wrench in the right direction. Facing the car, because the bolt is in the inside, I would be turning the wrench to my right to loosen, correct? I've actually tried both ways, but I want to make sure. Once I'm sure of the correct direction, I'll try some muscle with a pipe I have handy.
Thanks!
Ed
Old 09-23-2009, 10:02 AM
jsmithcds's Avatar
direction
Can off PB blaster +1
Piece of pipe on the end of a 1/2 socket for the muscle
Craftsman 1/2 inch impact wrench with a 30 gallon compressor(will run most air tools)
looking at the head off the bolt:
Lefty loosey ====> righty tighty
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust
Viper Green
He who laughs, lasts.
Old 09-23-2009, 10:17 AM
EMJ EMJ is offline
Bolts off! The pipe over the wrench in the right direction did the trick! Came off with minimal effort - thanks guys!
Been a while since I did a brake job - was suprised when I loosened the caliper by loosening the 4 bolts to get it off of the rotor when all of a sudden brake fluid started leaking all over the place when I separated the pads. Leaked for over 5 minutes until it was all out. I remember that being a valve that's loosened in my other cars. Didn't see any cut brake lines.
How do I bleed the brakes when I'm all done with putting everything back together when there's no bleed valve? Sorry for the basic questions, guys. Never have done brakes on my 911 before. Thanks.
Ed
Old 09-23-2009, 12:30 PM
4 bolts? Brake fluid drainage? There are usually only two caliper mounting bolts. Perhaps you somehow separated the caliper halves?
You will have some work to do before bleeding the brakes. Get back with us when you're ready.
Sherwood
Old 09-23-2009, 12:53 PM
pete3799's Avatar
Best buy a Bentley repair manual or Wayne's book as i think you've messed up. What 4 bolts are you talking about? You didn't take the calipers apart did you?
You should have a bleeder on the inside top of each caliper.
Pete
79 911SC RoW
Old 09-23-2009, 01:04 PM
EMJ, follow this link to the tech articles right here on PP. Always helps to do some research before grabbing the wrenches and then figuring out what went wrong afterwards.
Pelican Parts - 911 Technical Articles
Tony G
2000 Boxster S
Old 09-23-2009, 01:10 PM
EMJ EMJ is offline
Yup, working off of Wayne's 101 Projects. I took the 2 bolts off but the calipers wouldn't come off so I loosened the 4 caliper bolts and spread them so that I could clear the rotor. The caliper then cleared the rotor but then came all of the brake fluid.
Ed
Old 09-23-2009, 01:16 PM
EMJ EMJ is offline
Thanks, Tony. Actually had the plan all mapped out - read the Rotor replacement section of Wayne's book but didn't anticipate the caliper not clearing the rotor once the 2 bolts were removed. Figured loosening the caliper made sense, but didn't anticipate the brake fuid leaking.
Here's a question: What's the best way to remove the caliper from the rotor when it won't clear it? Didn't see this covered in Wayne's book. Thanks!
Ed
Old 09-23-2009, 01:21 PM
What's missing so far is some text describing removal of the rigid brake fluid line to the caliper. In addition, the brake pads are accessed by removing the brake retaining pins. You may have to push the caliper pistons in slightly to provide enough clearance to slide them out, but that's all normal SOP.
You've created a short cut by splitting the calipers - not recommended. And if you haven't removed the rigid brake supply line yet, the inner caliper half is probably still in place.
At this point, you may need more than the 101 Projects book. Learn the search function and exploded illustrations here first (they're free).
Keep in touch.
Sherwood
Old 09-23-2009, 01:30 PM
You want to use a pair of channel lock pliers (large adjustable type) grab the brake pads one at a time and squeeze them back so the piston moves inside the caliper. Once that is done, you could also removed the pads completely. Then you undo the two bolts that hold the caliper to the strut. If you are rebuilding and in need of complete removal, you need to disconnect the hard pipe feed line before removing the bolts that hold the caliper to the strut. With all that removed, the caliper can be lifted right off the rotor.
BTW, if you have gotten brake fluid all over your pads, do not reuse them.
Tony G
2000 Boxster S
Old 09-23-2009, 01:36 PM
safe's Avatar
You should have spread the the pads to get it of the disk.
Now you can have a problem getting the caliper leak free.
Magnus
Old 09-23-2009, 01:40 PM
