-   -   Compression test during valve adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/500911-compression-test-during-valve-adjustment.html)
MrScott 09-23-2009 07:05 AM
Being that I'm in the middle of a valve adjustment the oil is drained. Doesn't seem safe to turn the engine over so many times with only residual oil -- it's been sitting with the cam covers off for about a week.
Is there disagreement on this (safe vs unsafe) or am I being overly cautious?
Maybe I reassemble and swallow that pill if needs to come apart again...
docrodg 09-23-2009 07:24 AM
NEVER turn over an engine without oil in it.
BK911 09-23-2009 07:47 AM
Do a leakdown. Turn the engine by hand.
MrScott 09-23-2009 08:44 AM
Just to be clear, the engine isn't totally dry, it was running before I drained the oil and took off the valve covers. So I've already turned it over a bunch of times adjusting (and re-adjusting) the valves...
A leakdown is beyond my means -- no compressor, no gauges, etc. The motivation for the compression test is I noticed one valve was extremely loose during adjustment. Unfortunately I hadn't read the tech article cautioning against spark plug removal... I'm worried a piece of carbon might be responsible for that particularly loose valve making my adjustment off.
Hendog 09-23-2009 08:47 AM
The engine should be warm when doing a leakdown.
As for the OP; turning the engine by hand should be OK without oil for your compression tests.
MrScott 09-23-2009 08:54 AM
Alright thanks. I was going off the the tech article for compression testing using the starter.
Also read the rennlist post in this thread suggesting using the starter (or a short-skirted assistant :D) to turn the engine over during a valve adjustment.
Hendog 09-23-2009 09:01 AM
Actually, you may have to turn the engine with the starter to do a propper compression test; in which case I would WANT oil in there.
I've not done a compression test, so my thought on turning by hand is likely not the right way to get a compression reading, it just won't hurt the engine to turn by hand.
BK911 09-23-2009 09:26 AM
I've done dozens of leakdown tests on warm and cold engines. The difference wasn't that much. Plus you're only looking for a disparity across the cylinders so as long as all are tested in the same conditions you'll be fine. Imho of course.
Hendog 09-23-2009 09:32 AM
Your experience supercedes my "knowledge-by-reading-only" SmileWavy. I see your point on the disparity.
MrScott 09-23-2009 11:49 AM
Alright, so the consensus is button it up, compression test w/starter and spring for the extra oil if I have to drain the sump again. Thanks guys, I'd be lost without this place.
911pcars 09-23-2009 12:03 PM
Cranking the engine should be fine even with oil drained. However, the engine should be at normal operating temp. before performing a compression test (same with a leakdown test).
Finish adjusting the valves, run the engine, then perform the compression test.
Sherwood
MrScott 09-23-2009 02:31 PM
So say if an exhaust valve weren't fully seating, bringing the engine up to operating temperature and then running the compression test wouldn't hurt it? Sorry if I'm being dense, but my lack of experience combined with the cost/downtime of even a top end rebuild has me nervous...
I'm not looking to evaluate the overall health of the engine -- did that a couple of months ago with the PPI (which showed max 6% leakdown cold) -- just trying to verify I've adjusted the valves properly despite removing the spark plugs beforehand and possibly dislodging bits of carbon.
911pcars 09-23-2009 02:35 PM
Even if the valve weren't fully seated, the engine would have to run for awhile before injuring the valve.
However, if you didn't adjust the valves properly, e.g. too tight, a leakdown test might be a more accurate test to reveal the source of a leak.
Sherwood
MrScott 09-23-2009 03:13 PM
Sherwood
Excellent, just what I needed to know. Ideally I'd do a leakdown test but I've got no compressor and no gauges. It was really only one cylinder I was concerned was misadjusted/maladjusted? since it was so out of spec. Leakdown was consistent beforehand, which I'm assuming means compression was consistent so I'm looking for an outlier here. If none, I'm solid, if one (or more!) drive/tow to someone who knows what they're doing.
