Send a message via AIM to ViR2 Send a message via Skype™ to ViR2
Porsche Crest Problems with distributor
Hi,
I have euro 2.4T with zenith carbs. And have a problem with distributor. When I hook up vacuum to it, then at 2k RPM ignition becomes very late and engine dies. Mechanic told me, that it is due to that housing might be from other distributor. I I've ordered: 0.231.169.003. But now I have noticed, that the same is already installed...
So, question is... Distributor is rotating clock-wise, correct? Vacuum port is hooked to the right side, or to the left? (when looking at it installed)
I've got mixed at it... Maybe Euro and USDM distributors are different?
Regards,
Kristijonas Valius
'65 Porsche 912 #994
Old 09-22-2009, 10:49 AM
Band.
Perhaps the inside of the distributor is very dirty, and the weights and springs inside are not moving. Then, when the rpms come up, the mechanical advance is not working, and your timing becomes late.
remove thedistributor very carefully and open it up, and clean and lubricate it.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 09-22-2009, 10:58 AM
There are no differences with the euro or US distributors and all the 2.2/2.4/2.7 distributors spin clockwise. All the 2.4 distributors have the same advance curve so you should be fine with any 0.231.169.XXX distributor except the 001 which was a 2.0 distributor.
I'm not sure what you are asking about the vacuum port.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 09-22-2009, 11:03 AM
but when vacuum is unhooked, then everything is ok..
Regards,
Kristijonas Valius
Old 09-22-2009, 11:06 AM
Band.
take off the vacuum and check your advance at idle.
How much advance?
Then, rev to 4000 RPM or 6000 RPM and check advance.
How much advance?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 09-22-2009, 12:10 PM
mechanic told me that at idle its 7 degrees and at 4k-6k its 12 degrees.
Regards,
Kristijonas Valius
Old 09-22-2009, 11:04 PM
Check the internal ground strap connecting the breaker plate to the outer housing.
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 09-23-2009, 05:21 AM
Designer King
Paulporsche's Avatar
The 2.7 dizzies have a vacuum retard, not advance. The retard is not needed and can be disconnected w/ the line plugged.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-23-2009, 05:32 AM
these are 0.231.169.003 or they have different part number?
Regards,
Kristijonas Valius
Old 09-23-2009, 10:07 PM
0.231.169.003 is a 2.4T distributor 72 to early 73. As I mentioned, all 2.4 distributors have the same advance curve.
Old 09-23-2009, 10:12 PM
so with pluged in vacuum it should advance, not retard the timing? Currently mine retards
Regards,
Kristijonas Valius
Old 09-24-2009, 09:16 AM
Designer King
plugged means the line is obstructed or closed off. Plugged in means connected. Connected means it will retard @ idle.
Paul
Old 09-24-2009, 10:08 AM
I know English Just when I plug in vacuum line and try to rev - it dies, when checking timing, it is off by nearly 25degrees minus when reving, everyone is saying that is should advance when reved, but mine retards, so that's what I'm asking. Is my distributor POS, or maybe wrong distributor was installed, and it SHOULD retard when reving and with vacuum pluged in
Regards,
Kristijonas Valius
Old 09-25-2009, 06:30 AM
Band.
I think
that the distributor you have in there is dirty inside, and the mechanical advance in the distributor is not working.
take off the vacuum line and plug it for now. Set the timing of the distributor to 5 degrees before TDC. Rev the engine to 6000 rpm and the advance should go to something like 30-35 degrees before TDC.
If it doesn't, something is wrong inside the distributor and you should have it repaired.
When everything's working you should plug that vacuum line in and it should take the idle timing from 5 BTDC to 5ATDC and that's about it.
The car should run fine without the vacuum line. Many people don't even use it.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 09-25-2009, 07:10 AM
