Home alignment
Is there any good book on doing your own wheel alignment. I did the search and found numerous posts on home made measuring devices but no discussion of the way the adjusters work or interact?
Kent Olsen 72 911T
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Somatic Negative Optimist
Home-alignment for Camber and Toe is very easy, Caster can be left alone.
You'll need a camber-gauge (or make one from a carpenter level) and 2 jack stands with a string inbetween to set toe. Firts, decide on the height you want, then decide on what Camber and Toe you want, then do the alignment. What do you mean by "adjusters"?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Kent,
Ray Scruggs sells a booklet called Home alignment for your P-car. Tells you the whole story. I think it is inthe $10-20 range.
muck-raker
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Thanks guys.
