Gear oil
I am aware that some folks are using Mobil Delvac 1 Synthetic 75w90 SHC Gear Lube what is your feedback on it?
Is anybody using Redline synthetic gear lube or anything else?
Oh, this is for a G50
Thanks!
1987 Targa just about to hit 29k
2004 mazdaspeed miata wifes
1995 spec miata SOLD stupid fun!
Old 10-11-2009, 07:50 PM
3.4 Bigger is better
88-diamondblue's Avatar
I have used the flaps Mobil 1 gear lube and put in the Mobil Delvac 1 a few months ago with great results. This is what Porsche uses for factory fill on their race prepped cars. I have replaced the fluid every two years for the last 6 years. Overkill probably...
Just make sure the you can get the fill plug out before the drain plug
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 10-11-2009, 08:11 PM
Make Bruins Great Again
Por_sha911's Avatar
I replaced my lube with Redline for LSDs. I found it was harder to shift from first to second when the trans was "cold". After a minute or two it is better. This could be the Redline or maybe the PO was using a combo of LSD and non-LSD to get easier shifting. Bottom line is that now that it's time to change it out, I'm going to try something else.
p.s. Do a search and you will find a wealth of info on this topic. Just be sure you are using 75/90 synthetic for your G50 trans.
Joe
Old 10-11-2009, 08:18 PM
Northern Motorhead
wildcat077's Avatar
I'm using Quaker State 75W140 full synthetic gear oil in my 89 G50 Coupe and i like the
results as compared to 75W90 oil...Once the oil warms up it shifts way smoother !!!
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-11-2009, 08:42 PM
