electrical problem
I have read this interesting forum for quit a while. So here my first post.
My 71 911 has an electrical problem! The problem started after bleeding the front and rear brakes.
When I use the handbrake the turn signal indicators are on and the blinker flasher is making a buzzing noise. Also during driving the problem comes and goes. The turn lights, brake lights and other lights are all working normally. I did not yet tried the reset button on the master brake cylinder.
I do not understand why the turn signal indicators and blinker flasher are on, if the brake warning switch is the problem, because on the electric wiring diagram of 911 T there is no connection to the blinker flasher and turn signal indicators in the tacho. There is only a connection form the brake warning switch and hand brake contact to the e-brake warming light in the oil temp/pressure gauge.
Does anyone recognize this problem?
Thanks!
Old 09-30-2009, 01:48 PM
