Ruby911
RPMs drop when I turn headlights on - is this normal?
The title pretty much says it...The RPMs drop about 200 when I turn on the headlights. Is it supposed to? I dont recall that it used to do that. Any ideas on the fix, assuming it is bad?
Thanks, Farrell
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD 1968 Ossi Blue 912 Sunroof Coupe - SOLD 1971 911E - 2.7 Twin Plugged, PMOs - SOLD 1965 356C Outlaw RGruppe #577 |
Mine dip about 100 or so then recover immediately. It's from the additional current that instantaneously loaded the electrical system...
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
Doesn't sound normal to me. It it a true RPM drop or is just the tach reading dropping?
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Ruby911
The tach drops and the idle changes - almost like when I turn the AC on.
muck-raker
definitely not normal. Possible VR or alternator issue.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
check your ground , especially the battery to body , and the tranny to engine/body
if either are bad your electrical system is in trouble , and this may be its way of screaming for help ...
