LOUD humming/buzzing noise
So after getting something wet(see other post), i now have a loud humming/ buzzing noise all the time. Even with the key off and out of the car i still get this buzzing. :eek:
Its coming from behind the throttle body, a bit lower... The car is an 82SC ANY IDEA's??http://forums.pelicanparts.com/uploa...1254751608.jpg http://forums.pelicanparts.com/uploa...1254751622.jpg |
Fuel pressure? Maybe you didn't notice it before.
+1 on fuel pressure. That is in the area of the return line from the Fuel Distributor and you may be hearing the dropping of pressure especially since you hear it with all electrical off in the car. Have you measured your residual fuel pressure? You may have a fault in the system that's allowing a too rapid drop of system pressure after shut down.
Ive heard it before, but this time it stays on for a while. If i disconnect the Bat it turns off?? what is the sensor that is pluged in to the harness in the top pic?? when i unplug that it stop's also
I think it's the frequency valve, which bleeds off fuel pressure in the lower FD chamber thus lowering pressure to injectors. it's controlled via the o2 control unit under the pass. seat:( Taken from the Bentley manual sec 240-30)
you might want to pull that control unit out ASAP and flush it with some electronic contact cleaner and let it air dry a day or so. same with O2 relay, or replace O2 relay. Bummer. |
yeah that area got soaked yesterday, thats where ill start....
where should i start after that??:( |
I would disconnect the multi-plug and remove the Lambda brain with the relay from under the seat, carefully open it, inspect and dry it out.
Dry and clean the pins, use dielectric grease and put it back together. Fuse for the Lambda brain is the same one for interior light, clock, etc. The Frequency valve is controlled by the brain and has to work properly for the engine to run. |
cool, thank you......that was my next step...ill remove the seat and make sure its all dry under there, then remove it and dry it real good... Ill also check all the fuse's while im at it....( now that you mention it my clock has stopped working too) |
| All times are GMT -8. The time now is 01:07 AM. |
