Can you fit 17x9 16mm on the fronts?
Im trying to achieve a Jack Olsen-ish look
(hi jack). I have a 77 911 widebody non turbo with flared fenders. Im wondering if I can fit the 17x9 with 16mm offset in the fronts safely without any rubbage? later I plan on hunting for deep rears. What do you think? - If I'm on the wrong track please tell me the wheel size and offset I should be searching for. Thanks! -Baker. The look I want: ![]() ![]()
tire size also matter. I forgot what it is on mine. If you need it, let me know. I will look.
Fat butt 911, 1987 |
sweet, so that will fit the fronts? do you have pics with that setup? thanks.
yes any detailed info will be greatly appreciated!
255/40/17 is the tire size I ran up front with no problems. I did remove the evap canister and windshield washer tank in the left fender to prevent rubbing (though I'm not 100% sure this is necessary). 235/40/17 and 225/45/17 are other easy sizes to run. In the rear you can run lots of sizes from 275-315. Hmm...lets see what I can dig up for pics.
First off here's mb911's '77 widebody 911 with 255/40/17 and 275/40/17 tires on 9&11x17 Alton Fuchs: ![]() ![]() ![]() Then there's my project car - a '77 with earlier widebody bodywork. The first pic is with 9&11x17 TruDesign/Lindsay weldup Fuchs with 255/40/17 and 275/40/17 tires. ![]() The rest of the pics are with 9&10.5 Alton Fuchs ![]() ![]() ![]()
baq,
I have 255/45/17 on the front and it rubs to the inner wheel well on max turn. Also on the kick panel and fender lips. When I change tires, I would do 255/40/17. On wheel's specs. Look at pictures bellow. Hope this helps. back space ![]() front space ![]() width
Fat butt 911, 1987 Last edited by rnln; 10-06-2009 at 11:26 PM.. |
