BR
Flexible Injector Lines?
I've been seeing folks use flexible injector lines to replace the OEM ones. Does anyone have any information on where to get them? My car is a 82 3.0 SC.
Thanks!
82 911SC Targa
99 540i
Old 10-06-2009, 03:11 PM
Senior Member
Superman's Avatar
Lots o' guys prefer the steel ones you already have. Me, for one.
Mocha 1978 911SC. "Coco"
Old 10-06-2009, 05:22 PM
theiceman's Avatar
take them off a 78 or 79 SC
When I pulled off my CIS to refurb it they were a dream to work with over worrying about stiff lines that could kink , fracture, or just plane get in the way ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-06-2009, 05:53 PM
BR
Thanks...I guess I should have asked what are the pros and cons for flexible v. steel lines. The flexible look cleaner to me and give more working room but I wouldn't sacrafice that for performance.
I there a difference or is it like being a ass or breast man, just personal preference?
82 911SC Targa
99 540i
Old 10-06-2009, 09:00 PM
Almost Banned Once
sc_rufctr's Avatar
My 78 has black plastic lines... No problems with them at all in the more than 10 years I've owned the car.
That's impressive considering the car's 31 years old.
I always thought it would be cool to replace them with clear racing style plastic lines but never got around to it.
At some point I'll probably go after market EFI and throttle bodies so they'll be redundant anyway.
(looking for better fuel economy)
- Peter
Old 10-07-2009, 04:21 AM
kodioneill's Avatar
Plastic lines MELT. gas everywhere then FIRE.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 10-07-2009, 07:39 AM
hbf hbf is offline
I got mine from McMaster-Carr for flexible lines - black nylon tubing. Heat resistant up to 300f.
HBF
Old 10-08-2009, 11:32 AM
Senior Member
Superman's Avatar
Yes, personal preference. Like breast versus ass. For testing flow volumes, the metal lines are a LITA since they have to be disconnected in order to be moved.
But they are more robust in other ways. They don't melt. They don't fail but then, the plastic ones seem pretty reliable also. If they don't get bent or otherwise damaged, they would outlast the rest of the car.
Old 10-08-2009, 01:51 PM
metal lines are the way to go IMHO. You can order them from an authorized Porsche dealer. They are a direct replacement for the 30+ year old parts....think about it,
"I never had a problem...till my 911 burned to the ground go figure I had the lines on there for 30 years and poof one day they failed, go figure."
In 2005 the 6 lines cost me about $275.00 for Carlsen Porsche here in the SF bay area,
Old 10-08-2009, 02:32 PM
Recreational Mechanic
Nickshu's Avatar
Not sure what the advantages are, but early SC's had flexible lines, then after 1980 they went to steel lines....maybe for a good reason??
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 10-08-2009, 05:42 PM
Melting Point........
The melting point of the flexible (material) fuel lines is way too high for the engine temperature to melt it down. Even an over-heated engine at 275°F will not even come close to the transition glass temperature (Tg) of the plastic material. The cause of fire is due to leak/s in the fittings not on the fuel hose per se. The heat generated by the internal combustion engine is not sufficient to melt the 'plastic hoses' unless there is FIRE already in the engine compartment.
It should have been stated as "Gas everywhere then FIRE. Plastic lines MELT". .
Tony
Old 10-08-2009, 06:56 PM
