| 175K911 |
10-08-2009 09:58 AM |
Originally Posted by Bill Verburg
(Post 4941771)
my guess is it's the hubs that allow your very aggressive front o/s.
In back it's common to run sacers w/ the 9 ET15 wheels. To run 9.5 w/ max sized 275s ET19.5 centers the wheel in the available space, moving the oil line(not a big deal and grinding the trailing arm bolts(sorta scary) and lip work(can get expensive if paint work is also called for) will be needed for the wider tires.
It's been my experience that if it doesn't rub on a track it's ok for the street too.
I've got the car up on jackstands to flush the brakes before next weekend's DE so I'll take a look at the hubs and see if there's a difference. I should repack the wheel bearings anyway so it's a good excuse to pull the hubs.
I'd considered having Jeff A build me 9.5" rear wheels but decided it would make more sense to start with the size we know works, considering the unknown brake conversion variable. Based on what I run now, I could easily fit another 1/2" back there on the left, but would need to move the oil lines on the right. At the moment I'm OK with running 255/40 in the back so the 9" wheel is perfect..... for now. Gotta save my pennies for the 3.6 at the moment.
