-   -   Noob (mostly) 911 Steering "feel" question (http://forums.pelicanparts.com/porsche-911-technical-forum/503684-noob-mostly-911-steering-feel-question.html)
Mr_SpongeWorthy 10-07-2009 01:35 PM
Bear with me here, it is a long question, but the rather lengthy description is necessary due to the extremely subjective nature of the question:
OK, I've been seriously considering jumping into the 911 club. I do have limited experience driving a 1980 911 German import (helped my father research it about a year ago. He purchased it and it has been a great car so far.) I've driven it about 6 hours and 7 minutes total. 3 highway, 3 back roads and 7 minutes in an Autocross :)
What struck me the most was "that 911 road feel". I'm very comfortable with the rear-engine layout, so I'm not talking about the feeling of weight in the rear (a wonderful tool in autocross), but specifically about road feedback through the steering wheel. My father's 1980 feels like I'm caressing the road with my hands. Every single tiny imperfection is communicated beautifully into the wheel. If you're in a corner and there is a slight undulation, groove, or other imperfection in the road, not only do you feel the undulation, you can also feel which side of the car it is on. I swear you can almost feel how deep it is also. Despite this amazing agility, it is also relaxing and easy to drive on the highway. Straight as an arrow and perfectly stable.
I've just test-driven two 1986 911s. Both of them feel like pretty decent cars. They ran strong, drove straight and feel nice. But both of them lacked something in the feedback compared with my father's car. The steering wasn't "dead" certainly, but that brilliant instant feel was muted compared to his 1980. Since that is the only baseline I have for comparison, I don't know if there is something different about my Father's 911, or if I'm feeling worn-out front-end parts in these 1986 models? Should there be a substantial road-feel difference between the 1980 and 1986 models? (My understanding was that the suspension on these models was basically identical.) Might it be something as simple as an alignment difference?
Any input would be greatly appreciated!!!
McLovin 10-07-2009 01:50 PM
An 80 and 86 is essentially the same steering and suspension.
Tires, tire pressure and alignment all have a HUGE impact on steering feel.
Oh Haha 10-07-2009 02:06 PM
+1
I can tell a difference from mine in other 911's I have driven. Some better, some worse.
A thorough PPI will confirm of dismiss worn front end parts.
RWebb 10-07-2009 02:16 PM
did the later car have power steering?
tirres, alignment, etc. can affect this, BUT others have the same perception you do
gtc 10-07-2009 02:20 PM
The '86s are probably a little bit heavier too.
SpeedracerIndy 10-07-2009 02:22 PM
I think the weight of the car will have an affect too. My 81 euro no-sunroof coupe feels much more nimble and communicative in steering than my dad's 88 Carrera Targa. Mine feels like it has power steering compared to his too because of the weight difference. It is much more nervous and jumpy over bumps, where as the Targa is very squishy and muted.
McLovin 10-07-2009 02:23 PM
No power steering on any of the torsion bar cars. Power steering started with the 964.
I don't think the weight difference between an SC and an 86 Carrera would make a perceptible difference in steering feel (the components are too much the same), esp. when considering all of the other huge variables involved.
Flieger 10-07-2009 02:33 PM
+1 on alignment and tire pressures (and tire/wheel size).
lindemans 10-07-2009 02:39 PM
The 86 should be capable of providing the same feel as the older one you're familiar with.
Like others stated: the car is very sensitive to:
- quality of tires; due to the weight in the back, handling is very very sensitive to stiffness of the sides of the tire, for 16" far better tires are available on the market (tires with Porsche N-coding)
- suspension is a specialist job to get that right; unlike common springs the older 911 has torsion bars that need to be pre-set through manual adjustment to have equal load on all 4 wheels; only someone who really knows what this means can adjust this using a weight scale under each wheel; this is way beyond standard adjusting the front wheel alignment alone !!
These 2 items can make or break the handling of the car dramatically.
And of course low tire pressure, especially in the back, is killing
Fast Corners 10-07-2009 02:58 PM
Turbo tie rods make a huge difference as well. If the '80 has the upgrade to the turbo tie rods and the '86's have the standard tie rods you will feel a very noticable difference.
As others mentioned the alignment and tires make a difference. This does not even cover different torsion bars and or shocks and condition of bushings which have an effect on road feel too. It is phenominal what a good shock can do.
I'm going to throw my $0.02 in on the weight thing though. Even though the steering mechanicals are the same, the responsiveness and feel through the steering wheel, seat and pedals of the heavier cars to me feels slightly muted. Without pondering the question too heavily, I would say the inertia of the heavier cars has an effect on the "feel". My '73 back in her stock days felt more in touch with the road than the SC's let alone the Carrera's.
burgermeister 10-07-2009 03:48 PM
Condition of the rack makes a huge difference also. The grease can dry up and leave the internals with quite a bit more friction than intended. Friction is good for suppressing smooth road shake issues, and bad for road feel. The rack can be easily disassembled and re-greased (search for Tim Hancock and steering rack).
RWebb 10-07-2009 04:24 PM
Hmmm... have you compared the turbo with new non-turbo tie-rods?
- these issues just came up on the bushings thread, currently active
BTW - nice double pun on pondering the wt. issue
DanielDudley 10-07-2009 07:06 PM
I drove an 89 speedster a few years back with the turbo look body and wheels. It was one of the nicest feeling 911s I ever drove for steering feedback. It had 50K on the odometer, and was very original except for tires.
Fast Corners 10-07-2009 11:15 PM
Back in my wrenching days (late '80's to early 90's) I did make the Turbo tie rod conversion to a couple hot rodded Carreras (which were only a couple years old at the time). Usually people are not swapping out the standard tie rods for no reason so the comparison does not come up that much. ;)
In my opinion I think the Turbo's make a noticeable improvement. I read the other thread and have a few points to offer.
One thing to keep in mind is diminishing returns. If you have already set the car up with a lot of upgraded equipment, the difference in "feel" of any one particular improvement will have a tendency to be diminished in the grand scheme. For a stock road car the improvement of that one thing will "feel" like a greater change.
Two "feel" is definitely in the hands...butt...feet of the beholder. Some people are just more sensitive to the changes than others (I'm not saying that you or Bmeister fit in this category...if anything I would say it is the first one for you two). I once had a DE student that could tell even the minutest changes in yaw angle with is butt however his feet were made of pure concrete. Brake modulation was totally lost on this guy. My guess was that his a$$ was more directly connected to his brain than his feet were. End result of one session at Moroso was a trip straight off into the weeds on freshly squared tires.
Third thing is that rubber stores quite a bit of energy as it deforms. The absorbtion of energy reduces the magnitude of the transmitted force through that part. This can also be interpreted as a loss of feel. This is exactly the point of the big rubber disk at the base of the steering shaft...to reduce kick back through the steering wheel (and on to the nut that holds it...sorry couldn't resist). This is also why Porsche spent so much development time and money on the new dynamic motor mounts on the GT3 (greater response and reduced shifting of mass when you need it and more complancy when you don't).
dw1 10-08-2009 08:12 AM
It is possible that the difference in tire & wheel size caused much of the different "feel".
15" wheels were more common in '80, 16" in '86.
Type & width of tires? Inflation pressure? Both can cause VERY significant changes in steering feel.
One should also not forget to look at any difference in ride height, and whether the "bump steer kit" spacers were installed if the car was lowered.
Because I wanted to drive my car in cold weather, I went to ultra-high performance all-season tires. Results: poorer steering precision in hot weather, but better in cold weather.
My car ('87) is also lowered to euro ride height, and has the "anti-bump steer" spacers installed, which made an enormous difference.
Tyson Schmidt 10-08-2009 12:00 PM
SC's almost all came to the U. S. With Bilsteins.
Later Carreras almost all came with Boge Turgo- Gas shocks and struts.
I've also noticed that the Carreras with these Boges do not feel as light and nimble, and have a heavy, dead steering feel.
Bart_dood 10-08-2009 03:25 PM
+1, I have an 1988 and did the turbo tie rod upgrade, had the alignment professionally done and have high performance summer tires on the front. The steering feel is great and was one of the main reasons I bought the car.
longhornchris04 10-08-2009 06:18 PM
I can't separate the effects out, but I had the turbo tie rod upgrade & shocks replaced (w/ alignment, but the car's alignment was in spec before the suspension work).
Steering feel went from good, to I just ran over 2 quarters and a nickel. Ok, not that good, but I could definitely feel the road better - while simultaneously having fewer bumps translate to the chassis.
Tires also make a difference - and getting the right tire pressure is free. Tie Rods, well those cost a bit more.
RWebb 10-08-2009 09:45 PM
interesting
Tyson - have you driven Carreras with Bilstein repl. inserts in the Boge housings?
KNS 10-09-2009 06:47 AM
I agree with Tyson, I have found the same thing in steering and ride qualities (and how they were equipped) between the SC and Carrera.
Mr_SpongeWorthy 10-09-2009 04:19 PM
Ok, thanks again for valuable input. I think you've answered my question. Just to be sure I'm "getting it" - In essence, it looks like the later cars (Carerra), may feel dead compared to the SC, even when both are stock, but that regardless, if I'm willing to spend some money on upgraded tie-rod ends and/or shocks/struts, I should be able to get the feel I want (assuming I have the right tires and tire-pressure).
Does it sound like I've boiled that down to the fundamentals correctly?
Mr_SpongeWorthy 10-14-2009 01:06 PM
Back again. It turns out that my "baseline" car does indeed have the turbo tie-rod modification. So unfortunately this doesn't give me a very clear idea of the differences I should feel between the SC and the Carrera in stock form. I'll be test driving a stock SC sometime next week though, so that should give me some further insight. I have to say I haven't been overwhelmed by the Carrera "road feel" so far. I'm thinking I might be better off sticking to the SC series.
Bill Verburg 10-14-2009 01:39 PM
the suspension design on all '69 -89 911 is the same, differences in feel come from components, component condition and alignment.
For sporting feel, the 'live steering wheel' you want Bilstein shocks, turbo tie rods, 7 & 8" wheels(min), quality performance tires and quality performance setup. Of course the condition of all components needs to be nominal.
The lively feel comes form a combination of built in bump steer, steering axis inclination and scrub radius.
You can never get rid of all bump steer just minimize it, which factory alignment and height specs do, steering axis inclination is the result of front end geometry and caster settings, scrub radius is increased on an 8 vs a 7 vs a 6 the larger scrub radius increases wheel feedback through the steering.
If I were shopping for an '80s 911, I'd look for in order '87 -89, '84-86, then '78-83
Mr_SpongeWorthy 10-19-2009 09:39 AM
Thanks again for all the excellent feedback in this thread. I've only test driven 3 911s to-date, but none of them felt anything like my "baseline" car, driving which is somewhat akin to having some pretty phenomenal sex with the road (ouch!) :) That definitely complicates things a bit as I no longer have a "realistic" baseline on which to judge what I'm feeling in the cars I've been test driving. I'm thinking I'll have to rely more heavily on the PPI to tell me how the suspension is looking. I'm heading out to another test drive this Wednesday though, so maybe I'll get some more insight then.
