-   -   PMO/Weber filter element options (http://forums.pelicanparts.com/porsche-911-technical-forum/503885-pmo-weber-filter-element-options.html)
rbogh901 10-08-2009 02:31 PM
What are the options for air filters these days? Does K and N honor their million mile warranty? The rubber edge on mine is cracking and I'm wondering what the alternatives are. Thx.
rbogh901 10-08-2009 02:48 PM
And meanwhile, being basically a cotton element, what are the options for K and N cleaning solutions? Searches for K and N generally degenerate into discussions as to whether or not they are better than paper elements. I've used K and N cleaning, solution, cleaner, etc...
CruiseControl 10-08-2009 11:49 PM
While on this filter subject can anyone provide the K&N part numbers to suit the PMO / Webers
Have difficulty in sizing from the K&N catalogue
Paul
rbogh901 10-09-2009 12:01 PM
Does anyone clean their k an n's?
rfuerst911sc 10-09-2009 04:01 PM
Yes I do I use K&N filter cleaner.:D
Formerly Steve Wilkinson 10-09-2009 04:52 PM
Me too.
brads911sc 03-25-2010 05:28 PM
sorry to revive this thread. I have searched...
I have new PMO ITB's with rain shields and K&N filters. Does anyone make a paper filter element that is the same size and shape as the K&N?
rfuerst911sc 03-25-2010 06:18 PM
That seems to be the million dollar question :D. I have asked on several forums and no one seems to know of a " regular " filter in the correct size.
Formerly Steve Wilkinson 03-25-2010 06:40 PM
As far as I know, the K&N is the only one. If you maintain it carefully and oil it according to instructions, it works fine. I'm simply not losing any sleep over what micron size of particle is making it through. Life's too short.
Between ZDDP compulsives, filter wackos, Cool Collar hysterics--yeah, I've got one of those too, took it off my last airplane when I sold it--Magnacor fanatics, Swepco sissies and oh-god-do-I-have-the-wrong-sparkplugs worrywarts, we probably should just park our little dears and have them cryogenically preserved before we do terminal damage, like putting miles on them.
Drive the frikkin' thing.
brads911sc 03-25-2010 07:13 PM
Not at all obsessed with any of the things you mention... dont own a cool collar... run standard copper bosch plugs... however, I do prefer paper air filters... and if they made one Id buy it... just prefer to buy replacements and toss in the trash when dirty...
Steve@Rennsport 03-25-2010 07:42 PM
No paper element options for the PMO's: K&N's only.
I am working on some ITG options but those are inappropriate for most street cars.
James Brown 03-25-2010 08:52 PM
LOL!!! Thanks Steve!!!!
911pcars 03-26-2010 01:11 PM
I suspect K&N spec'd their housing to their custom-sized filter for a reason. I performed a serious search a few years ago, and K&Ns designed these housings to fit only their filter. An alternate filter housing that uses off-the-shelf paper filters would be a popular item.
I believe these foam filters are available from GCA Industries (True Flow) in Scottsdale AZ.
True Flow Yellow Porsche Filter 1965-1973
Part Number 85212
http://forums.pelicanparts.com/uploa...1269634136.jpg
Sherwood
JFG 03-26-2010 03:57 PM
Anyone use itg?
911pcars 03-26-2010 11:25 PM
Originally Posted by JFG (Post 5259819)
Anyone use itg?
Uhhh, yes.
http://forums.pelicanparts.com/uploa...1269670068.jpg
This was a previous setup with Filtron stamped Al. housings and modified Amsoil foam filters:
http://forums.pelicanparts.com/uploa...1269670822.jpg
Sherwood
rbogh901 04-28-2013 07:38 PM
Paul
Late to the party but here is something for those who might follow...
List Price: $61.68
E-3671 - K&N Replacement Filters, Custom Air Filter direct from K&N
James Brown 04-28-2013 09:10 PM
there is s thread on here where someone took a round fram filter and made it into a oval filter, best part they were only about 5 bucks each
ruby911 04-29-2013 05:21 AM
Anyone use itg?
Yep, but I wish I didn't ( I already had them so I used them). I think they are fine for race applications but worry about a street appilcation as I fear they will let rain water in. I spent last weeken at Road Atlanta for The Mitty and each night I had to put a rain coat over the motor to keep the deluge out. I would prefer, and will eventually get, some rain hats with K&Ns.
mskala 04-29-2013 09:58 AM
Info is about half-way down the page here:
http://forums.pelicanparts.com/porsche-911-technical-forum/619208-k-n-air-filters-webers-what-do-i-have-2.html
Note that the height is about 1/4" taller.
Pete000 04-29-2013 01:06 PM
One thing I noticed on the new K & N set up vs the old K & N set up is the mounting posts are not in the same location making the lids not interchangeable and the posts are pop riveted on compared to the more robust bolted on posts in the older design. On mine one of the posts just spun around making it impossible to tighten the nut.:mad:
The old NLA version is much better. IMHO.
Pete000 04-29-2013 01:10 PM
New and Old lids. Not interchangeable.http://forums.pelicanparts.com/uploa...1367266254.jpg
ganun 04-29-2013 01:20 PM
Ive been using 409 as the cleaner solution because the original K N sol smelled just like 409 to me. Still follow the instructions however, i.e. to only soak the outside of the filter while the solution is in a shallow pan, 1/4 " deep, when I lift the filter from the sol I can see the dirt fall away, then rinse from the inside out, dry and oil.
George
KTL 04-29-2013 02:10 PM
BTW just to add more hardware options, I recently ran across this Timmons Billet site.
Porsche
You can get some fancy brushed aluminum cover plates from them. A friend lives in Wichita and says Timmons is legit. Been in the racing business for many years and still around.
Mervo 06-13-2015 08:42 PM
Part Number 85212
Sherwood
Can these still be purchased?
merv
RichardNew 06-14-2015 09:09 AM
ITG is a good choice.
Richard Newton
Mervo 06-14-2015 03:49 PM
Thanks Richard. I will see if they have the oval version for the early filters as above.
Cheers,
Merv
Eric_Shea 06-24-2015 02:04 PM
Has anyone successfully used a stock 70's style filter housing with PMO's?
rswannabe 06-24-2015 02:32 PM
You mean like this? Stock factory airbox with custom base plates for PMO 46's welded into the lower sections that attach to the carbs. I run a K&N filter in my housing and cut off the snorkel for better airflow.
http://forums.pelicanparts.com/uploa...1435181530.jpg
jmz 06-24-2015 02:36 PM
back about 20 years ago, I used to run a 4 barrel paper filter element that I reshaped to fit the weber bases.
Trog 06-24-2015 02:56 PM
PMO ITB's on '84 3.2 using backdated air box:
http://forums.pelicanparts.com/uploa...1435182952.jpg
rswannabe 06-24-2015 03:07 PM
Trog - very nice! I have plans for that in my future. I want to go to EFI ITB's, but use them with the old airbox. Easy to do with the PMO ITB's.
Eric_Shea 06-24-2015 04:57 PM
Thanks Brooke!
Can the existing bases be modified on a drill press vs welding? I'm at Parade so I can't get my eyes on this and I'm looking for options for my mechanic.
911pcars 06-24-2015 05:58 PM
Eric,
AFAIK, the bases for Webers (maybe Solexes too) have the same screw hole pattern to the carb top (same as the velocity stack mounts). However, the lower "bathtub" portion of the AF housings are different and must be used with the correct upper section. The shapes are slightly different with clips in different locations. IOW, top and bottom portions must be compatible.
Fishcop 06-24-2015 10:16 PM
The Fabspeed airbox cover (painted satin black) is a nicer/quieter alternative than just cutting the snorkel too...
http://forums.pelicanparts.com/uploa...1435209327.jpg
rswannabe 06-24-2015 10:48 PM
Originally Posted by Eric_Shea (Post 8681947)
Thanks Brooke!
Frankly I do not know if you can just cut a few more holes in the bottom of the weber "bath tubs" to get them to bolt up to PMO's. I didn't try that.
rswannabe 06-24-2015 10:49 PM
Hmmmm. I'll have to give that a try to see how it compares to my snorklectomy.
