Send a message via AIM to Adidas
Bosch or NGK Spark Plugs? Chime in with your opinion.
My 93 911 has twin plug heads and uses a 3 electrode spark plug. Which is the better plug, the Bosch FR5DTC or the NGK BCPR7ET. I've used both. Any other good alternatives as well? Thanks Bill
Old 10-08-2009, 04:43 PM
moneymanager's Avatar
NGK's way superior. Bosch seems to suffer from quality control problems in my experience.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-08-2009, 05:28 PM
evill's Avatar
NGK. I use them in everything. I have always had the best performance in Porsches with them.
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 10-08-2009, 05:40 PM
KNS KNS is offline
NGK. When I owned a Honda years ago they were original equipment for that car, install and removal always seemed easier than other plugs. When I got the 911, I stuck with 'em.
Kurt
Old 10-08-2009, 06:15 PM
Make My Day
wowzer911's Avatar
E3 DiamondFIRE
74 911S Targa ROW
Building Designer/Business Owner
Old 10-08-2009, 06:44 PM
Manassas, VA
lucittm's Avatar
Moneymanager,
Can you be more specific with regard to "quality control problems..." Do you mean they foul easier/sooner, they are not made correctly, the materials are not adequate, or the variation from plug to plug is excessive?
Personally, I like the platinum Bosch for my 964 turbo. If NGK made a platinum plug, I might try it. I used NGK BP7ES plugs in my racing motorcycles and thet worked great.
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-08-2009, 07:15 PM
ngk or nippondenso are the best in my opinion
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-08-2009, 08:03 PM
Almost Banned Once
sc_rufctr's Avatar
Have always used NGK... Never a problem.
- Peter
Old 10-08-2009, 08:23 PM
LWJ LWJ is online now
I am a huge NGK fan. Back when I had a 65 MGB, the only plug that would run correctly in the crummy air fuel mixture presented was NGK. Since then, they have been my go-to. Cheap. Effective. Don't look elsewhere. Just bought some from Wayne last week!
Just my opinion.
Larry
Old 10-08-2009, 10:05 PM
tobluforu's Avatar
Run ngk in my viggen, would not run anything else; run bosch in the porsche as the stated ngk plug for my car would foul. Just put a hotter ngk in porsche in hopes that this will fix until I install the right cams for the pump that I have.
Old 10-09-2009, 04:44 AM
Designer King
Paulporsche's Avatar
I've used both NGK and Bosch plugs in my cars for 37years and never had a problem w/ either.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-09-2009, 12:59 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
ngk bp7es
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 10-09-2009, 03:02 PM
the most important thing to remember is stick with one of the two, versus any other brand.
they are essentially the same. I have never heard of any quality control problems with Bosch, FWIW>
Old 10-09-2009, 03:08 PM
