-   -   80 sc a/c question (http://forums.pelicanparts.com/porsche-911-technical-forum/504359-80-sc-c-question.html)
beany 10-11-2009 09:55 AM
80 sc a/c question
Hooked up the gauges, drew suction for a couple of hours, checked later and it held , put 2 cans of 134 in at 2000 rpm with a fan over rear condensor. High side got up to 250, low 55 at 92 degrees outside temp. Do I check final pressures with engine at 2000 rpm or idle? Thanks Any easy way to check temp at front vents?
Jim Sims 10-11-2009 02:46 PM
Engine at 2000 rpm. Stick one of these thermometers in the A/C dash vent closest to the evaporator:
Robinair 50945 Pocket Dial Thermometer - 1-3/4" Dial Face, 0-225F
