-   -   save or remove id sticker (http://forums.pelicanparts.com/porsche-911-technical-forum/504511-save-remove-id-sticker.html)
jhelgesen 10-12-2009 03:59 AM
I need to replace the lock post on the driver side of my car....
Has anyone ever successfully save and or removed the id sticker on the lock post? I was thinking of some clear tape and maybe a heat gun on the back side and a razor?
http://i184.photobucket.com/albums/x...DSCN4765-1.jpg
sc_rufctr 10-12-2009 04:22 AM
John
That looks difficult if not almost impossible to get of in one piece.
Can these be re issued by Porsche? It's worth a phone call.
Your idea of clear tape and heat may work but the age of the sticker is working against you.
There are solvents available on E Bay. Search "label remover"... (I just did and got some results)
It's designed to remove paper labels from computer hard drives etc in one piece.
I'm guessing that sticker is a metallised film which means you're going to have problem dissolving the adherent.
Try starting at the top. Swab a little on, wait a while and see if you can peel down the top.
Once you get it started keep going.... Good luck!
robmog 10-12-2009 04:49 AM
john,
can you replace only the lower section of the lock post?
that's what i did in my restoration.
of course, you'll have to protect the sticker from the weld heat.
try to save it, its original only once.
that being said, i made a replacement sticker ( shameless plug), if you damage yours.
see here:
http://www.early911sregistry.org/forum/showthread.php?t=14828&highlight=vin+sticker
jhelgesen 10-12-2009 05:14 AM
I have to repair to an area just south of the door latch, so working around it would be next to impossible. I'll keep the replacement sticker in mind, but this is one of the dotted cut ones, sure to self destruct if not careful. I could always carefully cut the steel out and rivet it back in place later.
docrodg 10-12-2009 05:20 AM
If it will destruct (probably will), and replacement is not available could you do as you suggest and cut it out but then take it to a local print shop and get it scanned and re-printed?
robmog 10-12-2009 07:27 AM
VIN shameless plug
here's my repro sticker installed (by alex in the netherlands).
he did it himself with my kit and instructions.
http://forums.pelicanparts.com/uploa...1255361038.jpg
jhelgesen 10-12-2009 07:35 AM
That works for me!
robmog 10-12-2009 12:38 PM
john,
like i said earlier, its only original once.
do try to save yours, but you can see a decent replacement exists if you can't.
you can see the #"s look a bit off since they were punched with a pin.
but its better than no sticker, mine was long gone in an earlier repaint.
tcar 10-12-2009 02:39 PM
Those stickers are designed to come apart with any attempt to remove them.
It's probably not going to work.
That repro is fair, but does not look authentic.
Por_sha911 10-12-2009 03:24 PM
Before you do anything, take some close up pics with a good camera of the sticker so that if it is destroyed, you have some evidence of what was originally there.
robmog 10-12-2009 03:40 PM
original VIN vs repop
looks okay to me.
http://forums.pelicanparts.com/uploa...1255390697.jpg
http://forums.pelicanparts.com/uploa...1255390807.jpg
Grady Clay 10-12-2009 04:28 PM
I agree with the above. Absolutely go to extreme effort to save the original in original condition.
You cannot remove the decal and preserve its appearance. Save the metal. You may use ice and other to weld close without damage. Be very careful and practice with replacement decals. Anything much above 100C will discolor the decal.
There is only one original and that is an irreplaceable original. It adds significant value to your 911.
It is too bad many others didn’t take the care.
Best,
Grady
