Brake Boost source
Hey guys,
Does anyone know the source of the vacuum hose that supplies the booster unit? The rubber hose is supplied by a connector on the floor of the hood and connects directly to the booster unit. Where is the rest of the plumbing? ------------------ DW 89 Targa |
It runs trough the car to the rear. Then into the engine compartment with the fuel lines. Then it plugs into the engine.... (not sure exactly where)
Ben in SC |
Hello
The rubber hoses are runing onto a pipe witch goes complete trough the car. Porsche does stock them new and even sale them. If you need a fast replacement the every standard vacuuum hose from every european car will fit. Just bend it and cut it at the right lenght. Grüsse |
| All times are GMT -8. The time now is 12:30 AM. |
