85 carrera rear sway bar bracket advice
i am looking for picture or exploded view of rear sway bar bracket and where it attaches to sway bar. someone advised me that is might be cracked and causing noise, but i am a new owner and am not sure if i am looking at right part. i can see sway bar wrap around plate and bushing, and drop link and bushings, but am not sure where bracket is in location to them. thank you!!(new 3.2 owner)
Old 10-14-2009, 11:28 PM
The stock swaybar mounts are made of sheet metal and welded to the unibody. They are known to tear away from the car under hard use. Wevo makes a cast steel replacement that is a lifetime fix. This:mounts the swaybar to this:which is welded to the underside of your car.
Old 10-14-2009, 11:58 PM
