-   -   Please help a newbie..Targa won't start (http://forums.pelicanparts.com/porsche-911-technical-forum/504918-please-help-newbie-targa-wont-start.html)
magnuskgc 10-14-2009 11:34 AM
OK so I am finally getting to work on a project. I have an 85 Targa that was initially bought to donate it's drive train for another project. That didn't pain out.
OK so here is my problem. It's an 85 Targa... The engine cranks over real strong but it will not start. Normally that would be an easy fix. Check to make sure your getting fuel and spark etc...
Here is the problem... I am used to american cars and not quite sure where everything is... I didn't hear the fuel pump which I assume I should hear kick on...
So my question is... what are common problems that would create this.. like fuses relays and such.. and how or where to look? Factory alarm?
Any help would be great.http://forums.pelicanparts.com/uploa...1255545265.jpg
Joe V 10-14-2009 11:42 AM
Check your DME relay. It's a know source of trouble as you describe. The unit is the size of a standard square relay, only twice as tall.
We always carry a spare just in case.
Welcome to the board and good luck!
Oops! Forgot to mention it's under the drver's seat right next to your DME control unit (big square silver box).
chamilun 10-14-2009 12:11 PM
you should hear the fuel pump running with the key in position 2. Some will claim its not supposed to, but it always does, at least on the SCs.
Id check the fuses and make sure you have none blown. located under the front hood.
good luck
McLovin 10-14-2009 12:28 PM
It doesn't on a Carrera.
magnuskgc 10-14-2009 12:57 PM
Good advice so far... I will going back in the morning... thanks guys keep em coming
magnuskgc 10-16-2009 07:32 AM
Dme
OK so here is a shot of the are under the driver's seat... I do not see the DME relay or the spot that was discribed.
Is something missing or am I just blindhttp://forums.pelicanparts.com/uploa...1255703546.jpg
stlrj 10-16-2009 08:03 AM
Looks like you found your problem!
twistoffat 10-16-2009 09:00 AM
The relay switch is between the silver box in the centre of your picture( the main control) and the bell like metal dome in from of that. As you can see from the pic you posted its missing. The connector is connected to nothing
magnuskgc 10-16-2009 11:20 AM
thought that was the powe seat connector... The DME plugs in there??
twistoffat 10-16-2009 11:44 AM
The large silver box is the DME control module and the metallic circle is the altitiude sensor. Whats missing between is the main fuel pump relay. Thats what the plug is for.
magnuskgc 10-16-2009 11:53 AM
fuel pump relay
and that is the DME relay? Anybody know a part number?
Thank you sooo much for the help guys
kidrock 10-16-2009 11:58 AM
911-618-154-00-m252
twistoffat 10-16-2009 11:58 AM
Porsche 911 Carrera Motronic Fuel Injection (1984-89) - Page 2
magnuskgc 10-16-2009 12:23 PM
Dme
got a spare one from a friend of mine... gonna give it a try.... cross your fingers...
thanks guys... I will let you know how I make out
magnuskgc 10-21-2009 02:15 PM
Running
It's alive!! thank you all so much for the info... amazing how much easier it is to get the car to start with a DME relay plugged in where it should be!
Thanks allot guys,
kidrock 10-21-2009 07:16 PM
DME relays are the weak links on the 3.2. Always carry a known good one for a spare.
Congrats, the cheap and easy fixes are always the best.
80-911SC 10-21-2009 07:50 PM
poor guy , first factory ran low on roofs and needed to hit production numbers and sent any way , also must be the cabriohoodless or factory ran out and someone stole the dme ...
best of luck ... :cool:
DRACO A5OG 10-22-2009 12:21 AM
Well, now you discovered the Ghetto kill switch. Remove relay and car will not be stolen.
Unfortunately can be towed though.
Glad it was an easy fix.
theiceman 10-22-2009 03:03 PM
with his luck the theif will have a DME relay in his pocket ..
magnuskgc 10-22-2009 05:16 PM
yes that would be my luck..... but thanks for all of the help guys
