mca mca is offline
mca's Avatar
What is the trick to installing new fan belt?
Got myself a new OEM fan and outter pulley. Figured I add a new OEM fan belt.
The belt is a Genuine Porsche belt 9.5 x 710. I can't even get the outter pulley to mate with the fan. It is really close though.
The newness of the pulley and fan make for a very snug mating fit which is adding to the difficulty ... but they do fit b/c I tested prior to trying to install the belt.
Is there some way to make the belt more pliable? Can it be heated up? What is the trick? My tech warned me that it would be difficult when I bought the belt on Friday.
FWIW: Previously I was using a Contitech 10 x 710 belt which I installed new a few years ago. After a year I was only using 1 shim inside of the pulley and 5 on the outside. I tried to install the Contitech with the new fan and pulley but it is too loose even with 0 shims in and 6 shims out.
Thanks,
Craig
EDIT ============ > the ContiTech belt DOES in fact fit with 1 shim in and 5 out. Intitially I thought it would be too loose prior to fully seating the belt and tighening the fan nut.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-05-2009, 07:57 AM
kodioneill's Avatar
Here's one method
How to change a VW fan belt - Car Videos on StreetFire
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-05-2009, 08:23 AM
mca mca is offline
mca's Avatar
^^^^^^^^^^^^ I expected that ^^^^^^^^^^^^^
Now onto finding a solution ....
Old 12-05-2009, 08:56 AM
Banned
It's very tricky installing a belt. What works for me is tape.
I put the shims where I want them, and then tape them in with masking tape.
A lot of jiggling and wiggling and eventually it goes.
I hate it. Those shims drive me crazy.
Old 12-05-2009, 08:57 AM
mca mca is offline
mca's Avatar
Yea, but in my case the shims aren't the issue. Even if I delete all shims (just for test fitting) I can't get the pulley to mate with the fan.
At least the fan install was easy. Took 5 mins. Hit the woodruff key on the first try.
Old 12-05-2009, 09:01 AM
Banned
Hmmmmm, Maybe get it started cockeyed, and turn the top pulley with your pulley wrench.
I know your frustration. It should slide on the bottom pulley.
It is a difficult process.
It would be nice if that nut on the alternator was longer so you wouldn't lose the shims in the pulley.
Old 12-05-2009, 09:16 AM
Put the belt and pulley on and tighten a little then turn the fan by cranking the engine for second , then go back and tighten the rest of the way. Maybe if it is really tight you will have to turn the fan and tighten a couple of times. I wouldnt heat it up.
Old 12-05-2009, 09:37 AM
Yeah what Dipso said I hadnt read his post. Sorry
Old 12-05-2009, 09:41 AM
Owner, Callas Rennsport
TCallas's Avatar
Craig, this procedure does take some practice. I like to use a thick heavy grease such as Bosch grease on the pulley shims to hold them in place. I think there should be 7 of them to make all work properly but this doesn't sound like your main problem. I also like to put the belt in the crankshaft pulley and pull up hard on it to seat it in the lower pulley better which might help gain some room at the top. Then put the upper pulley in place at an angle but seated in the slots to make sure it is aligned, put the shims and nut on and slowly tighten while turning the pulleys and engine to make sure all is OK. Hope this helps, Tony
Phone: 310-370-7038
Located in the Greater Los Angeles Area
http://www.callasrennsport.com
Old 12-05-2009, 09:45 AM
seems the prob is that belt is too tight
I'd probably try to install the old belt to confirm no mechanical issues
wild guess, although I've never seen it, is that belt is mislabeled
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2009, 10:12 AM
mca mca is offline
mca's Avatar
Thanks fellas.
Well I think I got it. Won't test it today b/c it is raining. I'll post results tomorrow.
I managed to get the pulley on with 6 shims inside and 0 out. I tightened the alternator nut to 30 ft-lbs while holding the fan pulley with the pulley tool. I then turned the engine over using the pulley tool and pressing on the right side of the belt in order to get the belt to ride up and seat.
Everything seems to be in order ... but dang ... that belt is tight. The deflection calls for 5mm or .2 inches. I am sure that I am in that range but as we all know this measuring technique is subjective.
I hope that it loosens up after I run it for a few minutes.
It is okay to have 6 in and 0 out right? As long as there are 6 total?
Old 12-05-2009, 10:15 AM
mca mca is offline
mca's Avatar
The old Contitech belt was too loose even with 0 in and 6 shims out. Again it was a 10 x 710 which seems to be an issue for many of us.
The new belt I got matches my spare original belt. Same part numbers and both 9.5 x 710. I used to run 4 shims in and 2 out when I had that belt on when I bought the car.
Old 12-05-2009, 10:22 AM
muck-raker
kidrock's Avatar
while you're out test-driving it, listen closely for any slight whining or grinding noises...usually a telltale sign that the belt is too tight, and causing strain on your alt bearing.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-05-2009, 10:31 AM
i was trying to say that maybe the new 9.5 x 710 is mislabeled and is too short
that wild guess figures that you know how to do a good install. It can be a pia doing it
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2009, 10:33 AM
excellent point
i install as loose as possible
if I quickly whack the accelerator linkage and the belt isn't flapping it's tight enough for me
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-05-2009, 10:37 AM
mca mca is offline
mca's Avatar
I am starting to second guess myself now.
It just occured to me that I have never really had to "torque" the alternator nut. I have always tightened it until it stopped - without strong arming it of course. Always used the nut to turn the engine during valve adjusts too.
But right now the nut will still turn. Suggesting that the belt will continue to rise up and get tighter. I need to go back out there and check it again.
Yes, my biggest concern is damage to the alternator or even the fan (scraping on the housing).
Old 12-05-2009, 11:06 AM
"It is okay to have 6 in and 0 out right? As long as there are 6 total?"
Probably a little atypical, but not wrong.
Aside from the minor difficulty of keeping the shims in place while installing the outer pulley half, I always find that I have to install that pulley half so that it seems to be pinching the belt, then turn the crank and re-tighten the pulley nut, maybe even several times, but the belt will be forced to assume its proper position. It will be forced to "ride up" the pulley.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 12-05-2009, 11:10 AM
mca mca is offline
mca's Avatar
Thanks.
This is exactly how I have always done it. Belt is pinched and then turning the engine over causes it to seat properly. At this point my biggest concern is the tension. New fan + new pulley 1/2 + new belt. It is tight - I also don't want the fan housing it to crack. Those are pricey.
Going to do some searching now and see if anyone else has had a similar issue.
Old 12-05-2009, 11:32 AM
If you have the belt seated properly and the nut torqued to 30 ft.-lbs., it should only deflect five mm, which is slightly less than a quarter-inch. That's pretty minimal deflection, and the nice thing about the deflect-with-thumb test is that we all have pretty much identical thumb strength, as long as you're not putting a Schwarzneggar's worth of upper body behind it. So press it hard with your thumb and if a quarter-inch is all you can get out of it, you're fine.
Stephan Wilkinson
Old 12-05-2009, 11:51 AM
Wyvern's Avatar
I thought the magic number of total shims was 7
any combination but always 7
Brian
Old 12-05-2009, 11:58 AM
