Thermal Fuse Options? Clock Repair
I've searched the old posts but I'm hoping for an update.
The VDO clock repair calls for solder for a thermo fuse. Spec. is 120C or 248F. Does anyone have a good option for making this repair? Is the solder available? |
I've read a few posts and threads about using low temp solder as a substitute. I've also read about guys that just use regular solder for the connection and effectively make it permanent and then add a very low current inline fuse in the wiring behind.
I'm partial to the inline fuse addition. Low temp solder is bound to break fairly easily and you'll be back with a non-working clock. Probably a good idea to get the movement cleaned and re-oiled as well.
1973 911T | Four owner car | My stewardship (2008-Present) 1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten |
good luck |
Try Mouser Electronics. They have a number of options for you to use. Search for "thermal fuse"
Thanks guys
How about a recommendation for a "very low current inline fuse"? Apparently the "thermal" vs. "current" protection isn't an issue. Would a spray electro/mechanical contact cleaner/lubricant be advisable? You know, the stuff you use to clean the tuner or volume pot on your old radio... Thanks for the Mouser Electronics site. Being the knucklehead I am, I guess I need a few less options. Can you narrow it down to "this is the one you want"? |
Last cast for replies....anybody?
Thanks |
If you search in this forum you'll find lots of threads on this. A search for "clock fuse" just now returns lots of useful info. I think there are some people who fixed this with a diode. Some has used other things.
1973 911T | Four owner car | My stewardship (2008-Present) 1972 VW Super Beetle | Two owner car always in the family | Gone, but not forgotten Last edited by DSouth; 10-15-2009 at 06:13 PM.. |
I was thinking of taking my clock apart again and cleaning it with carb cleaner and WD40. but contact cleaner sounds like a better idea maybe. the little solder attachment on the back didn't seem like a big deal,, just re solder it back on.
but then, my clock doesn't work, so my opinion doesn't count...
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
All good.
Yes, I had done the forum search. Always good info. This is such a great forum! Just thought I'd check for any updates, or new experiences from the brain trust. My path is now clear. |
