1974 911 w/ 83 SC engine
About to switch from dino oil to synthetic, any reason why I shouldn't?
I've been running Castrol GTX 20/50 for a while, on a rebuilt 83 SC motor that has about 90K miles on it. I just ran through a tank of gas w/ Chem tool B-12 in it and am now about to change the oil. I want to go with Royal Purple 20/50. I am absolutely_not_trying to start another oil thread, I just want to hear, if there are any, legitimate reasons why I should not switch to a synthetic. Also, has anyone heard of doing a "double oil change" after running a can of Chem tool or Techron through their system? As in, drive through a tank of gas w/ Chem tool, change your oil with something cheap--run that only for a little while, like 20-30 miles--then change that oil with the oil you use in a regular oil change? Apparently it works to get rid of any carbon deposits that might be loose in your engine after using a Techron-type product. Total BS?
Old 10-24-2009, 03:53 PM
The only reason, besides cost, that I can think of is the possibility of increased oil leaks. Other than that, no.
As for the double oil change, it's just like in chemistry class when they say to rinse things twice. Yes, you should be removing more contaminants with a double change. Is it necessary? I kind of doubt it unless your engine was really carboned up badly to begin with.
Does it run any better after having used the Chem tool product?
Scott
'78 SC mit Sportomatic - Sold
Old 10-24-2009, 04:11 PM
When I purchased my SC it had a very small oil leak. I changed to synthetic and the small leak got much bigger. Changed back to dino and the leak returned to it's former self........
*2005 Markleeville "Death Ride" 5 Pass Finisher. 129 miles & 15,000 ft. of climbing
*California Triple Crown Member (3 Double Centuries in 1 Year)
*2003 Giant Carbon Fiber Road bike with Topolino Wheels + a lot of goodies
*2000 Torelli road bike - Campagnolo Chorus equiped + a few goodies
*1999 Litespeed titanium, full-suspension mountain bike Shimano XT equiped + a lot of goodies.
Bill Carcot
1979 911SC - Sold (Searching for a Boxster)
2000 BMW Z3
Old 10-24-2009, 04:18 PM
Oh Haha's Avatar
Just get a case of Brad Penn 20W50, change the oil and be done it. Depending on how many miles you drive, you can determine your oil change intervals.
I, too went synthetic before I knew about Pelican and had bigger/more leaks.
Pacific Blue
Wayne
Old 10-24-2009, 04:23 PM
Kevin Stewart's Avatar
ill take the oil leaks with the increased protection of synthetic, Kevin
Old 10-24-2009, 04:37 PM
A dino oil designed for flat tappets is better than a synthetic that is not. Choose wisely.
FYI- Brad Penn is partial synthetic.
Old 10-24-2009, 04:47 PM
OK, what dino oil is designed for flat tappets? Is Royal Purple specifically not?
Old 10-24-2009, 04:59 PM
Make Bruins Great Again
Por_sha911's Avatar
Flat tappets need Zddp. Do a search, read up on which oils have the most. Unfortunately the reformulation puts most oils and the bottom edge of minimum amounts of Zddp needed. That means you have to change oil more often. Sooo, why spend more for an oil that you change more frequently? Are you doing DE's or Auto-crosses in the desert? Do you park the car outside in 20 below zero weather? You don't need synthetic.
Having said all that, C Navarro does say that some full synthetics are [U]as good as[U] Brad Penn but, why spend the money?
Joe
Old 10-24-2009, 05:08 PM
When Syntec first came out, I changed the oil from regular Castrol to Syntec. The only weight available at that time was 5w50. Leaks followed the oil change. I changed back to regular "Dino" and have not had any problems. I do use Valvoline 20W50 VR-1 racing motor oil now due to the increased amount of ZDDP over regular motor oil.
www.exeterautosupply.com
1976 911S Targa
Old 10-24-2009, 06:23 PM
theiceman's Avatar
Royal Purple is high in Zddp and is a good product ... Even Penn State . or Brad Pen or whatever it is called is a semi synthetic .. that is what I run ... on my 78 . no complaintes ..i don't thinkthere is any real benefit to synthetic since these engines and bearing clearances were designed arounf dyno oil ... but if you have all that money with nothing to do with .,, go ahead ,,
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-24-2009, 06:56 PM
Thrlls's Avatar
I had the same question when I first got my Carrera.
The previous owner ran the same dino you are running.
I did the Techron thing, then got some flush from Lubemaster, and ran some Amsoil 20W50 HD Motorcycle oil as recommended by C. Navarro.
Drove for 7k miles and changed the oil and it wasn't very dark, still had a golden look to it.
Refilled with the same...no leaks yet, engine runs cool also...just a tick below the second line on the gauge.
With all of that said, I now don't think that dino is all that bad either as it was mentioned when this motor was built it was with dino oil.
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 10-24-2009, 07:27 PM
Sit back, relax, and read...
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
Old 10-24-2009, 07:29 PM
Mo money = mo parts
It sounded like you were suggesting to change your oil, then add Chem or Techron. The more common approach is to add these additives just prior to your normal oil change cycle. The recommendation to add these gas treatments just prior to an oil change because they can seep into the crankcase and they really aren't designed or intended to be there. Most formal and informal evaluations suggest that Techron and a few others do a good job of removing deposits and operating smoothness of the engine.
+1 on the Brad Penn comments or adding ZDDP. Not all synthetics would be good for your car. Focus on the brand of oil and whether it meets the specific needs of your car, not the general category.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-25-2009, 06:09 AM
[QUOTE=gregwils;4972209]It sounded like you were suggesting to change your oil, then add Chem or Techron. The more common approach is to add these additives just prior to your normal oil change cycle. The recommendation to add these gas treatments just prior to an oil change because they can seep into the crankcase and they really aren't designed or intended to be there. Most formal and informal evaluations suggest that Techron and a few others do a good job of removing deposits and operating smoothness of the engine.
+1 on the Brad Penn comments or adding ZDDP. Not all synthetics would be good for your car. Focus on the brand of oil and whether it meets the specific needs of your car, not the general category.[/QUOTE
No, no, I specifically mean using the gas treatment, then change your oil with something cheap and just have in your car for 20-30 miles, THEN drain that, and do an oil change with what would be your normal oil (brad penn, etc.) I don't know where in my first post I suggested doing the gas additive AFTER an oil change, but that would be completely counter to what I'm trying to achieve with the double oil change. Basically the first 20 mile oil change is used to wash out any extra carbon, gunk, etc. the gas treatment dislodged but didn't come out with the first draining.
Old 10-25-2009, 08:34 AM
911s with a front oil cooler take 11-13 quarts of oil to be full. When you drain the tank and sump, you'll recover about 9qts. Leaving 2-4qts of old oil in the system that you can't drain! Last time I changed my oil (Brad Penn) I drained out the old oil then added 6-7qts fresh 15-40 I had on hand. I then ran the car 20 or so miles to mix it all up, then drained again before adding the new Brad Penn. Still couldn't get all the old oil out absolutley, but a least I knew it was pretty much all new oil!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 10-25-2009, 11:47 AM
theiceman's Avatar
tip ... before doing your oil change drive home in a gear lower than you normally would .. i do this all the time nd it spikes the oil temp .. when I change the oil immediately on getting home ..... and i mean within a minute or 2 of stopping the engine .. the stat is open and it pours out. I actuallu got 11.75 quarts out.. a record for me ...
Old 10-25-2009, 07:28 PM
Old 60's Porsche Tech
captainlewis's Avatar
Use any synthetic that you like and add gm eos one pint per oil change. Your zddp will be right on the money. Synthetic oil does not cause oil leaks, leaking gaskets and seals cause oil leaks. I have changed over a half dozen high mile 911s to synthetics and never had one leak attributed to synthetic oil, also you dont have to worry about changing sooner, yo will have all the zddp you need. If you dont want to mix use 20/50 mobil one for 4 stroke motorcycles and you will have the same thing. The "dont use synthetics" message went away with the dinosaurs, except for a few, JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 10-25-2009, 08:16 PM
Originally Posted by captainlewis View Post
Use any synthetic that you like and add gm eos one pint per oil change. Your zddp will be right on the money. If you dont want to mix use 20/50 mobil one for 4 stroke motorcycles and you will have the same thing. The "dont use synthetics" message went away with the dinosaurs, except for a few, JL
I've heard a lot about it, but where do I get the GM eos? Can't find it in Austin. Also can't find_enough_of the mobil 1 20/50 for motorcycles, as every store I've gone into only has ONE quart in stock at a time. And there aren't even 12 stores that have the one quart for me to buy enough for a change.
Old 10-25-2009, 10:18 PM
Sounds good, I'm going to try that. Just have to work on the reflexes of getting my hand out of the way in time before being boiled by the 210 degree oil.
Old 10-25-2009, 10:22 PM
You can gm eos at a gm dealer if you can find one. about $12 a pint you can order by the case called gm eos assembly lube, J:
Old 10-26-2009, 08:51 AM
