-   -   Remove Triggers from door handles? (http://forums.pelicanparts.com/porsche-911-technical-forum/507037-remove-triggers-door-handles.html)
StayGold808 10-25-2009 06:50 PM
Hi All,
I'm wondering, is it possible to remove the outer door handle triggers from the handle itself? I'm not sure how to remove the pin that the trigger hinges on.
Thanks,
Adam
joefrantz 10-25-2009 08:15 PM
On my 73 you just tap them out with a punch.
I'm pretty sure the later handles are the same.
This may help:
http://forums.pelicanparts.com/porsche-911-technical-forum/347343-door-handle-assembly.html
Joe
StayGold808 10-25-2009 09:46 PM
Thanks for your reply... Exactly what I needed
The problem was, i hadn't removed the stud with the hex nut.
madmmac 10-26-2009 07:56 AM
Not sure where you are at....this may help.
http://porschedoorhandles.com/Instructions.pdf
StayGold808 10-26-2009 10:27 PM
thanks for your reply.. Yes I got them off...
But on a side note, man oh MAN is that website you posted a rip off!
moneymanager 10-27-2009 08:04 AM
Here's a useful thread...
[url=http://forums.pelicanparts.com/porsche-911-technical-forum/334534-trigger-door-handle-disassembly]
A search will find several others.
