-   -   CIS fuel filter. how often do you change it (http://forums.pelicanparts.com/porsche-911-technical-forum/507304-cis-fuel-filter-how-often-do-you-change.html)
T77911S 10-27-2009 04:13 AM
the title says it all.
i have at least 30k miles on my filter.
i checked my tank not long ago and it was very clean.
what symptoms would you expect from a dirty filter? high RPM bad performance? bad starting? or just bad all around performance
i have another one ready to go on, just curious, actually a slow day at work and looking for something to talk about.
sc_rufctr 10-27-2009 04:47 AM
I change mine bi annually and I drive my car about 10,000kms a year.
I know that's way to often but my 911 is one of the few luxuries I allow in my life.
I've never had any issues with my fuel system so I can't comment on the symptoms of a dirty filter.
What does the service manual say?
As an example according to the Bentley, my VW Golf VR6 filter should be changed every 50,000kms.
(This car also gets a new filter bi annually)
Hope that helps.
don gilbert 10-27-2009 04:51 AM
i have a 75, and i like to change it at least once a year, but i only drive it around 5-6 k a year. If your 77 is like my 75 the pump is in the rear, and there is enough room to put a filter in front of the pump. Gives me peace of mind. Napa has a short clear plastic one with 2 10 mm fittings, works great, very easy to change.
T77911S 10-27-2009 04:55 AM
pump is up front. i guess i am long over due
Sunroof 10-27-2009 05:05 AM
CIS needs clean fuel and a filter is a cheap insurance! I change mine once a year and I might drive up to 5K if I am lucky!
Bob
73.5T
Gunter 10-27-2009 10:05 AM
Depends somewhat on size.
SC's have big and small depending on what year.
I like the bigger one and configured the lines and fittings for it.
Mark it with date and Mileage for referrence. :)
AshEvan 10-27-2009 06:06 PM
unless its a stock 74
Try and find those original OEM fuel filters for a 73 1/2 and 74 CIS . . . $$$$$$ if you can find them.
Fortunately my car came with 3 extra filters per original owner records, over 22K miles and still flowing fine.
