Gas line leak, near front left tire.
Today I noticed, while my car was running, a small wet spot began to form in front of the left front tire. It was gas. Looking directly up from the spot I saw a small (10-13mm diameter) braided hose that was wet. It wasn't the larger those that ran parallel to it. Does anyone know what hose this is?
There is an evap cannister that sits above the windshield washer reservoir.
It could be either the cannister is full or the hose is just leaking or both. The hose is just common fuel hose. I think the routing is from just below the filler neck in the trunk, into a metal fuel line going out into the wheelhouse, then into the rubber hose and into the cannister.
My guess is that the rubber fuel lines going to/from the evap. canister are old and cracked. This happened to my car too. The evap. canister is basically an overflow tank that sees gas when you over fill your tank. The hoses are easy to replace with standard fuel line - press on fit with hose clamps I think. The line is not under any pressure so you don't need high pressure hose and fittings etc...
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
Thanks. Anyone know the size of this hose? (Length, inside diameter and outside diameter if that matters.)
Michael Delaney wanna-be
This number will have all your answers: 888-280-7799
88 Carrera Cab C.R.A.P. Gruppe Member #7 |
N-Gruppe doesn't exist
what year is your car?
my evap box is cracked so when i overfil it leaks how about some pictures...
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Most likely your fuel fume collection system tank is cracked.
Recreational User
Here's an older post of mine with some nice diagrams...
Fuel Evaporation / Emission System: '71 911T
'88 924S - Stone Grey Metallic |
Davie boy,
That was very helpful. Thanks. |
Now I just need some dimensions so can go to my local auto parats star and getthe hose.
Anybody now the length and inside diameter of this hose? |
Pull the old one out first and take it with you!
Somatic Negative Optimist
Tom said it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Looking at the PET, they call for 9x12 and 15x21 hose. Just buy some lengths of each and cut to size.
