84 911 stumbles below 1700 RPM help
my baby stalls below 1700 RPM . i have put a new ECU , DME , O2 sensor , set all mixture levels .... when this happens it DOES have a clicking I think in the DME relay .. it seems to just cut out at around 1000 RPM when starting out .... cold hot makes no difference ... changed out the flow meter, no help ...running out of options AND money any help would be nice
Old 10-29-2009, 10:41 AM
does the car buck at all before it stalls or does it just stop dead. If it is bucking check you cylinder head temp sensor, I had that issue. If it just stops, have you tried a new red relay (fuel pump relay) Other than that check you fuel filter and/or test your fuel pump. Good luck
Old 10-29-2009, 10:46 AM
will try red relay and change out fuel filter ....put new head temp sensor in didnt help ...its a BUCK ... if the relay and the filter does not help i am lost $$$$$$ am running out LOL
Old 10-29-2009, 10:52 AM
How does you distrubtor look, perhaps taking off the cap and checking for carbon build up, I have heard of a bad or dirty distrubtor causing misfires, and on the rare occasion bucking, not sure if it would stall the car completely but it seems probable
Old 10-29-2009, 10:57 AM
red relay..no help.......
Old 10-29-2009, 11:05 AM
How many mikes on the engine? I have heard similiar issues around the speed sensor on the flywheel, missing and bucking but never stalling. Has it been slowly getting worse or staying the same?
Dave
1984 Porsche 911 Carrera
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 10-29-2009, 11:27 AM
miles....
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
100,000 not distrubtor cap its new
Old 10-29-2009, 01:02 PM
staying the same but consistent
Old 10-29-2009, 01:04 PM
