Alternative to Innovate LM1?
I have Innovate LM1 and far too often get the ERROR 4 - PUMP OPEN message.
After many times removing/replacing sensor plug into read out box the unit functions properly - untill the next time I want to use it. Sent the unit back to Innovate and they "fixed it" Same problem exists. So - Does anyone have exprerience/suggestion of other manufacturer's AFR reader? Appreciate any input EPS |
I hope someone has an alternative as well, the LM1 is a terrible product. They have a good warranty, but 3 O2 sensors in a year is excessive. All of the sudden I would get a zero volt reading, solution was a new sensor three times, then a new controller twice. After that I sold it.
Funny, I have nothing but good things to say about mine. It was a godsend as far as tuning my oddball MFI 3.0L application.
Where was your O2 sensor mounted? They are very sensitive to over heating, so if you used the sensor bung on the SSI's, that could have been the cause of your trouble. It will overheat even with the heat sink. The only place I've been able to mount mine to get any kind of life out of it has been in the tail pipe, using their clamp made for the purpose. |
Been very reliable for me for the past 4 years. |
AEM UEGO Controller. . . available at NAPA
Parts #s AEM30-4100 Six in one Gauge type UEGO controller AEM30-2710 10 channel Peak & Hold Injector driver AEM30-2204 K type Thermocoupler Amplafier AEM30-2300 Single channel UEGO Controller AEM30-2301 DUal Channel UEGO controller Catalogue says prices start at $364.00 |
| All times are GMT -8. The time now is 02:10 PM. |
