Down on power after adjustments
After recently changing plugs, disty cap and doing a valve adjustment, My car doesn't have the "seat of the pants" power that it did before. It's really noticable at full throttle in second and third gears. The car is a '70 911E w/webers and a Pertronix lighter. Any ideas?
Thanks, Mark ------------------ Mark B. Wilson 1970 911E mbwilson@home.com http://www.marksobsessions.20m.com/ |
Friend of Warren
My guess would be you either retarded the timing or messed up on the valve adjustment.
Kurt V 72 911E |
Mark,
Have you checked the ignition advance at idle and at 6000 rpm to see if within spec? ------------------ Warren Hall 1973 911S Targa |
Haven't yet. Just got a timing light and will look at it this aft. I did go back and recheck the intake valves. there was one that was too tight.
Thanks guys, Mark |
