Ignition skipping a beat?
My 78 SC runs rough on idle, and when driving at steady speeds. Not very comfortable. When accellerating it runs very well now, after these changes:
1. Put in a used distributor (From a 79).
2. New Permatune CDI-box.
3. Coil verified working.
At first I was trying a rebuildt distributor, which fell apart inside when driving, so I can't trust that one even though it was put back together
I can hear, feel and SEE the problem, when using a timing light on idle I can see that it skips a flash when I hear the engine "skip a beat" and drop in RPM. Is this normal, or can I have some other part which is messing with the ignition?
I know I may also have issues with slight air-leaks and possible uneven fuel flow (Low pressure, maybe, will have it measured), but these things should not cause the symptoms described above.
Picture of the car, which is a daily driver from May to October, in snowy Norway
Old 10-31-2009, 03:11 PM
You don,t mention replacement spark plug wires. I would suspect they could cause a cut out.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 10-31-2009, 06:41 PM
steely's Avatar
+1 on the wires - observe the engine in the dark for evidence of arcing.
Plugs ok? Maybe a cracked /dirty insulator?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-31-2009, 10:21 PM
Hi, and thanks for replies! I did actually change the plug wires last year, to some pretty good quality insulated ones. The plugs were also changed at that time. But I will certainly check both out!
Old 11-01-2009, 01:01 AM
T77911S's Avatar
MCA put a new set of wires on his car and it ran worse, put the old ones back on and it ran better, put the new ones on, bad again. perhaps try swapping 2 plug wires, dont forget you have to move both ends. see if the problem follows the wire. also check the dizzy cap.
do you only see it on the one wire?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-03-2009, 05:51 AM
SC-targa's Avatar
Did you replace the distributor cap and rotor? I once got a cap with a bad carbon electrode in the cap.
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 11-03-2009, 08:02 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Check your primary wire, the one from the distributor to the permatune. It has a wire shield around the insulation, my insulation broke down and shorted the "points" signal.
eric
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-03-2009, 05:04 PM
