Leaking Cam Tower Fitting
I seem to have a small weep at my left side cam tower fitting where the banjo bolt attaches. Is it likely just the crush washers? Also is there anything other than the two crush washers there that may need replacing?
thanks, Ben
1986 3.2 Carrera |
Checked out
I'd just try tightening it a bit first and see what happens. If that doesn't work, new crush washers might fix it, or it can be the actual line is leaking where it is crimped. That is common.
