1978 Porsche 911 SC alternator belt
Replaced alternator belt and it snapped in half again. Cloud of smoke etc.... Car still starts so I don't think its alternator. Any ideas? Thanks in advance. Only 3 shims on bolt could lack of shims cause problem?
Old 11-05-2009, 08:44 AM
Model Citizen
herr_oberst's Avatar
you need a total of six shims.
snapped in half?
Old 11-05-2009, 08:50 AM
pete3799's Avatar
Does the alternater turn freely?
It should turn easily without the belt on.
Pete
79 911SC RoW
Old 11-05-2009, 08:53 AM
How do I determine if alternator is turning without belt on?
Old 11-05-2009, 03:36 PM
Formerly known as Syzygy
Canada Kev's Avatar
Turn the pulley with your hand. If it turns, then the alternator is turning. If it doesn't then no, it is not turning.
Kevin
Old 11-05-2009, 03:41 PM
That belt is one of the 9.5x725, 77to 79 was the odd size
Bruce
Old 11-05-2009, 04:36 PM
You need to clarify things just a bit, after confirming the alternator is not seized.
As herr_oberst said, you need six shims, total, in some combination--between the pulley halves and between the bolt and outer pulley. You said you have three. Is that three total, or three between the outer pulley and the bolt? Do you have all six shims?
As Bruce posted, do you have the correct belt? What size is the one that broke?
Yes, improper number of shims can cause your problem. Let us know what you have.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-05-2009, 05:03 PM
