-   -   Source in US for wheel spacers? (http://forums.pelicanparts.com/porsche-911-technical-forum/508985-source-us-wheel-spacers.html)
StayGold808 11-04-2009 06:18 PM
Hi all,
Technically I mean wheel adapters (the kind that do not require longer studs).
Can anybody recommend a source for me?
I'm after 54mm rear, and 31mm fronts.
Thanks,
Adam
47silver 11-04-2009 08:08 PM
try our host pelican
Pelican Parts.com - Wheel Spacers/Adapters
StayGold808 11-04-2009 08:47 PM
thanks for your reply... i saw them.. but they aren't in the sizes i require.
Kevin Stewart 11-04-2009 09:11 PM
google boothe spacers, Kevin
StayGold808 11-04-2009 10:28 PM
thanks, had a look but the sizes don't match my application.
I could maybe go 1mm or so thinner, but definately not thicker.
proffighter 11-04-2009 11:27 PM
Here you'll find them:
http://www.cargraphic.de/stepone/data/downloads/28/00/00/Distanzscheiben.pdf
They got an US dealer: Road Sport Supply - Home
gumba 11-05-2009 06:56 AM
These guys will make any thickness spacer or adapter (hub centric) you want. Wheel Adapters, Wheel Spacers, Hub Rings, and much more! | Motorsport Technology
Kevin Stewart 11-05-2009 08:24 AM
boothe will build the spacer to your needs call him, Kevin
jinos 11-05-2009 09:58 AM
Off subject a little but are spacer/adapters that bad for your car? I heard if it's more than 2-3 inches it puts too much stress on your wheel bearings. Is that true?
Deschodt 11-05-2009 10:14 AM
Google "H&R springs" website, then find a vendor close to you... I got mine off ebay USA....
StayGold808 11-05-2009 06:09 PM
Thanks for the info.... I've sent a few emails..
