Is sand blasting really using sand?
Hi, is sand blasting really using sand? I was under the impression that I just bought a bag of fine sand and use but I could be wrong. If not, where do I get the stuff I need?
Thanks, David |
Unregistered
Sand blasting uses sand. Glass beading uses fine silica or garnet, media blasting can be anything from soda ash to plastic.
It all depends on your equipment and the parts you want to blast. Sanblasting is very abrasive and will remove metal, that's why critical parts are glass beaded. |
Sandblasting does mean the use of sand. But the term could be used kind of loosely. People here tend to be pretty accurate though, by using terms like Glass or Plastic bead, Soda, Sand or peen blasting. There are different grits and sizes of the media also.
Try to source locally by looking in the Yellow Pages or the Thomas Register. I believe Eastwood and others sell via the internet as well. That being said you'll need a decent sized compressor and good respiration protection...be prepared for a mess unless you have a blasting cabinet.
Warren & Ron, may you rest in Peace. |
How about bumpers on a 77 911. I am just getting lazy and don't feel like anymore chemical stripping?
Thanks, David |
There are dozens of media used in "sandblasting" including many grades of plastic media, several grades of sand, silica carbide, crushed walnut shells, glass beads, etc. Your choice of media, and how much pressure you use, depends on what you're trying to accomplish. What are you doing?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Banned
David,
If you are looknig for sand for your blaster you might try a local cement or concrete company. I buy my sand locally at a place that sells sand for these companys along with all sorts of rocks and stones for water foutains,patios.........etc |
Wavey you said walnut shells!!! Here in socal off the 5 freeway near the train yard is a huge pile of crushed walnut shells that gets sent out to various places. Never knew what it was until I needed some. Used it to blast some funky paint off an old house.
If you are only stripping bumpers chemical stripping is pretty fast and would be cheaper unless you have access to a large blasting hood or acid dip tank. I have used Aircraft stripper, that stuff is the best.
74 911s neverending story. two feet and a jetta for now. |
Banned
************************************************** Argeo, I had my bumpers on my '77 bead blasted, then primed and painted. No problems at all. Looked great.
Terry 1981 SC |
I wouldn't sandblast the aluminum bumpers - it's too aggressive and you'll spend more time priming and sanding over and over to get them back to square one. But the paint would grip exceptionally well!
I agree, aircraft stripper is the best thing to use for this purpose.
Certified Pre-Owned
I did and its not a problem. With the appropriate primer build this is the fastest way to go.
'84 Carrera Coupe |
Friend of Warren
What BG says. Using fine sand to sandblast a bumper gives you a perfect surface for priming. A good primer-surfacers will easily cover all the etch marks.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Unregistered
The best and easiest way to get something blasted (no matter what you want to use) is to find a local buisness that does that for a living.
You take the parts and explain what you want, they take care of it and you hand them some bucks. Fast, easy, clean. Most places like that employ blasters who really don't make much money so overhead is low. I bet they'd do bumpers foraround $20 each. I have a 14' x 12' fully enclosed blasting booth in my shop at work and we don't even use it any more, not cost effective. We just call BD&G sandblasting, they pick up and deliver. I can get very large (tons) complicated parts powder blasted for a couple hundred, no way could my people do it that cheap. Definitely worth farming out. |
nice doggie
I would get aluminum parts media blasted by someone who does that for a living. We have a local guy who charges by the hour. Doesn't cost much.
Jerry 78 SC hotrod 02 Mini Cooper S |
Actually, very few people use sand anymore. If they do they are risking a lawsuit for silicosis. Most "sand" these days is aluminum oxide. 220 grit should be fine enough not to do any metal damage.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
If anyone knows of a cheaper place in the area please let me know.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. Last edited by Wavey; 11-04-2004 at 03:20 PM.. |
I've sandblasted countless car parts and later primed/painted them, and it really is the best way to go. Especially if there is even any rust. As someone else stated, the primer sticks like mad. I always used a buildable, sandable primer and it easily fills any imperfections from the sand. That said, you can warp panels by sandplasting them aggressively. The sand I prefer is called "Black Beauty" and boy does that stuff cut!
Thanks everyone for the input.
After all the input I have decided I will use sand. As far as paying someone around here to do it (MA), labor ain't cheap so I stick to the do it myself. I'll make a few phone calls to see the price and report back. As far as sandblasting, I'll keep a distance and try to go lightly. I would think sanding any imperfections on the bumpers would be the easy part. Can't I just use a 80 grit paper on my orbital sander (I think that is the name for sander running off compressor). Please correct me if I am wrong here to prevent undue suffering. I used Aircraft remover for the whole car and am now tired of scrapping. Figured I have the tools, might as well use them so I can spend my time doing something a bit more constructive. Plus winter is coming so time is an issue also. Thanks again everyone. I would certainly be screwed without this board. David |
David,
I recently sandblasted a project car. I made a sandblasting/paint booth like others on the board. Just swapped the plastic sheeting after completing the blasting. I used "Play sand" from Lowes. Beware, breathing the dust from sand blasting can cause lung damage (silicosis). I used a fresh air mask/hood. Here's a picture of the booth. I made it big enough to park the P-car in. Don't worry, I didn't blast the car!
Evan --------- 1987 sun roof coupe |
