Brake Light Switches
After a little research, it is time to replace the two brake light switches on my 85 911 (brake lights are not coming on until pedal depressed a couple of inches). Forgive the stupid question but, will I need to bleed the brakes once this is done? Thanks.
MBruns for President
Yes. Search on the topic - several good threads. The good side is you don't have to remove the MC to replace. The bad news is it a bit of a pisser to get at.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Hi
Actually I've replaced those 2 switches without needing to bleed the brakes.
Find yourself a 2x4 or broom handle cut to the right length (sorry, i don't know what that is at the moment); to press the brake peddle about 1 inch, doing this closes off the system and a minimal amount of brake fluid is lost. Also, if you do bleed the brakes, invest in one-way check valve bleeders, that make bleeding the brakes a whole lot easier.
"A good sense of humor is the best thing to have in your toolbox when working on these cars." Quote by Charles Freeborn, Pelican. |
abides.
Graham 1984 Carrera Targa |
Make Bruins Great Again
Is it possible to replace the switches without bleeding the brakes? Yes.
Is it better to bleed them? TO be on the safe side, yes. Besides, if the fluid is more than two or three years old you really should do a flush of the system anyway. Why have world class brakes and bad fluid (which equals poor braking)? p.s. The search button is your friend.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
