-   -   Rotate engine for valve adjust w/no access to lower nut? Ideas? (http://forums.pelicanparts.com/porsche-911-technical-forum/509457-rotate-engine-valve-adjust-w-no-access-lower-nut-ideas.html)
911Freak 11-07-2009 11:49 AM
Hey Pelicans
I'm doing a valve adjustment on my 1980 3.0 (930/08)
Problem is I can't get access to the nut on the main pulley to rotate the engine because this 3.0l came with A/C and thus there is little to no clearance between the engine mount bracket and the double crank-case pulley to get the 26mm socket attached?!
Bentley, 101 projects and Haynes simply state to use a 26mm socket to access this nut and rotate engine, however they offer no recommendation for an alternative :confused:
I have been trying to use the upper pulley (alternator/fan) but with the resistance from compression the belt slips :(
I'm sure a pelican out there knows a solution ;)
Thanks in advance SmileWavy
Tigerrat 11-07-2009 12:00 PM
Usually squeezing the belt together while turning alt. nut works. I think I used a work glove to avoid getting pinched. You could push on one side with an open end wrench too. Ken
sailchef 11-07-2009 12:07 PM
you use the nut on the alternator not the crankshaft, and pinch the belt like tigerrat explained
Christien 11-07-2009 12:28 PM
Yep, that's the way I always do it. Just swab some glue around the pulley to hold the belt.
:D
Just hold the belt to the pulley with your finger - doesn't take much pressure to stop it from slipping.
Walter_Middie 11-07-2009 12:34 PM
Put the car in gear and push it.
911Freak 11-07-2009 12:34 PM
Got it, Thanks guys!!
Canada Kev 11-07-2009 01:41 PM
Is the belt tight enough? Mine is, but it still needs a bit of a pinch. When I did my first valve adjustment, the belt was way too loose, so I needed to move some shims around. This gave me the opportunity to take a closer look at my belt. It was cracked a bunch on the inside. Time to replace. Maybe it's telling you something?
911pcars 11-07-2009 02:14 PM
Connect remote starter switch to the starter solenoid and bump the engine into position. Make sure the ignition is OFF.
Sherwood
Rob B 11-07-2009 05:40 PM
Pull the spark plugs first! Rob
docrodg 11-07-2009 05:51 PM
Pull plugs, bump engine. Then should be able to turn belt to final position.
911pcars 11-07-2009 11:00 PM
The "final position" doesn't have to be TDC. As long as the rocker arm for the cylinder is contacting the heel of the cam. That's the area the valve remains closed to adjust clearance.
While the engine can rotate easier with the plugs removed, leave them installed.
This reduces the chance of carbon flakes dropping off and temporarily lodging between valve and seat.
Sherwood
Brando 11-08-2009 12:42 AM
For the fan pulley nut, use a shorty extension. To turn the engine over, pinch the belt then turn clockwise. DO NOT TURN COUNTER-CLOCKWISE!
Formerly Steve Wilkinson 11-08-2009 05:36 AM
Rob's right. Pull the plugs. Way easier to do valve adjustment with the plugs out.
Gunter 11-08-2009 07:26 AM
911Freak,
Along with valve clearance, I usually make sure that the rocker shafts haven't moved and check the torque on the head studs with a long 10mm Allen socket.
If you take the plugs out, you can check them for gap and condition. :)
pete3799 11-08-2009 07:27 AM
I wouldn't pull the plugs before doing a valve adjustment.
If you do you risk dislodging carbon build-up that could get trapped under a valve and
affect your adjustment.
Chances are it won't happen, but why risk it.
john walker's workshop 11-08-2009 08:21 AM
this is correct. the engine will turn over with the alternator nut easy enough if you push in firmly on the right side of the belt as you turn the pulley with the wrench.
Gunter 11-08-2009 08:36 AM
Yeah, never take the plugs out even if you need new ones after 50k Miles. :rolleyes: :D :D
Every now and then, a thread appears like: Help, cannot get plug out. :(
Reason? Carbon build-up on the plug end. It'll move for a couple turns and then seize. It'll take some force to get it out. The danger here is that damaging the threads is quite possible because the plug is steel and the heads are ALU alloy.
If the plugs are left in for too long undisturbed, it might cause problems. :eek:
What to do?
IMHO, Nothing wrong with taking them out now and then to check condition, gap and carbon build-up. SmileWavy
bcgreen 11-04-2014 04:10 PM
Gunter, I bet you don't see many P cars in your town?
TheSt|G 11-04-2014 04:33 PM
5 years later, he might not even have it anymore...
The cap'n 11-04-2014 04:34 PM
NEVER remove the spark plugs before you adjust the exhaust valves! There's a good chance you'll dislodge bits of carbon, and a very good chance (Murphy's Law) some of those bits will end up on a valve and/or seat, throwing off the adjustment. I recommend a remote starter button and watching for individual valves to fully open, adjusting the opposite valve each time that happens. As for the intervals, I would never run a spark plug in a 911 for more than 15K miles, especially in a turbo.
The Cap'n
Nick Triesch 11-04-2014 07:23 PM
I believe there is an article on this site that says remove plugs before doing valve adjustment. What to do!
The cap'n 11-04-2014 11:12 PM
OK. I guess the instructor at the Porsche school was wrong. What did he know, being factory trained and all? Pardon me (and all the other experienced techs).
The Cap'n
theiceman 11-05-2014 06:29 AM
What to do?
no one is saying dont take the plugs out , merely dont take them out while doing a valve adjustment. After my valve adjustment is done and while i have all the leads off .. THEN i pop the plugs out for an inspection.
The cap'n 11-05-2014 08:31 AM
Because the seal on each plug is a crush washer, it's supposed to be a one-time use item. I haven't seen replacement washers in years, although they're probably still available somewhere. You used to be able to get them in various thicknesses, for those who indexed their plugs. Dunno if you can still get those, either.
The Cap'n
SkunkWorks 11-05-2014 10:31 PM
Off topic but for plugs, I heard that what colour they are doesn't truly depict how rich/lean the car is running?
I can't fathom how combustion and the associated colouration that comes with it would be any different to a "normal" engine...
The cap'n 11-05-2014 10:41 PM
Lead is a big factor in plug color. The absence of lead in modern fuels has made plug reading pretty much a thing of the past.
The Cap'n
SkunkWorks 11-05-2014 10:45 PM
Good thing I've a AFR wideband kit in the mail then!
Thanks cap'n!
fred cook 11-06-2014 04:34 AM
Valve adjustment
If you really want to use the crankshaft nut to turn the engine while doing a valve adjustment, just drop the muffler. With it out of the way there will be plenty of room!
911pcars 11-06-2014 08:39 AM
Originally Posted by 911Freak (Post 4997503)
Hey Pelicans
Here are the ways to rotate the crank (engine OFF):
1. Rotate crank pulley with wrench or equivalent
2. Remote starter switch (or disable ignition circuit and use the ign. switch to crank)
3. Roll vehicle forward while in gear (parking brake OFF)
Your choice to remove spark plugs or other engine pieces with the usual caveats about debris around the plugs.
Sherwood
