-   -   hugh rust problem now what (http://forums.pelicanparts.com/porsche-911-technical-forum/509715-hugh-rust-problem-now-what.html)
dfink 11-08-2009 05:59 PM
Well it may be the death of the C.R.A.P. legend. Was pulling the gas tank today in preparation for a new 5 gal fuel cell and for some reason decided to stare at the front suspension. I was pondering how low should I go. Anyhow just happed to notice small spot next to the drivers side front suspension mount point. The very front where the torsion bar tube connects. Trouble extends at least half way across the front uniframe. Anyhow pictures say it all but how what do I do.........
http://forums.pelicanparts.com/uploa...1257731834.jpg
http://forums.pelicanparts.com/uploa...1257731849.jpg
http://forums.pelicanparts.com/uploa...1257731875.jpg
http://forums.pelicanparts.com/uploa...1257731890.jpg
sc_rufctr 11-08-2009 06:08 PM
I've seen a lot worse... Mostly caused by stray battery acid.
It's a very common problem but certainly not terminal.
I'm not going to state the obvious but everything to fix this is available and all the
info can be found here by searching any number of rebuild/back date threads.
TimT 11-08-2009 06:15 PM
Thats not a rust problem..
Man up and fix it.. its not to hard to fix
john walker's workshop 11-08-2009 07:31 PM
normal, unfortunately. some repair panels are a lot better than others, mostly in the way the front a-arm mounts are welded on. 3 spot welds doesn't get it.
audiman08 11-08-2009 07:42 PM
My suspension pan is starting to rust a little around one of the torsion bar mounts also. The suspension pan is the first to start rusting I hear.
jpnovak 11-08-2009 07:44 PM
New pan. Done in a weekend. Piece of cake repair.
motley911 11-08-2009 08:37 PM
I found the same thing in my RSR a 2 weeks ago. I was working on the front fitting an oil cooler duct and not expecting to find what I found.
http://forums.pelicanparts.com/uploa...1257741045.jpg
After some drilling, grinding and a few strategic "bumps" with a hammer
http://forums.pelicanparts.com/uploa...1257741115.jpg
And finally the new pan - fits like a glove.
http://forums.pelicanparts.com/uploa...1257741276.jpg
Its not too hard of a job - it took me about a full weekend to get to this stage.
Good luck.
sc_rufctr 11-08-2009 09:12 PM
This is from another thread... You need to look at this.
Pan Inspection With Borescope - Early 911S Registry Bulletin Board
450knotOffice 11-08-2009 10:56 PM
Welcome to the suspension pan/tank support rust club. My car had it pretty bad when I bought my car five years ago. The offending parts were cut out, and new parts were welded in (not by me, mind you, I don't have the proper welding tools for the job). It's been good as new ever since.
dfink 11-09-2009 06:46 AM
Doesn't look so bad now that I see there is a replacement pan. Will start looking for the part. On mine the seams must be buried in undercoat.
Rot 911 11-09-2009 06:52 AM
My avatar is a picture of me replacing the front suspension pan on my '72. Gave me a good excuse to go out and buy a MIG welder and learn how to use it.
dfink 11-09-2009 09:05 AM
Well I took a look at the replacement piece pelican has and it didn't look very substantial. The area where the suspension bolts looked very weak. Any input on their supply.
No offense to pelican as I will likely be ordering 1K in tranny parts soon but anybody have a supplier of good parts. PM so we screw with the host.
Other option since this is a race car and the tank was being replaced anyhow would be to cut out the offending rust area and install a tube or box. With plates for attaching the front of the torsion tube. This however might violate rules against tube frames so should probably go back original.
500_19B 11-09-2009 09:12 AM
I ordered Dansk parts from a vendor in Ohio that begins with "S". Very happy with the fit and the amount and quality of the welding for the LCA mounts. My story is here:
http://forums.rennlist.com/rennforums/911-forum/499091-battery-area-surprise.html
dfink 11-09-2009 12:20 PM
So what gauge of metal should I be looking for when locating parts.
sailchef 11-09-2009 12:46 PM
Any parts allready stamped out as replacements will probably be 18-20 gauge. You will be surprised to find most of the sheet metal on a Porsche is pretty thin. Its allways double walled and crimped etc. to give it strength.
sailchef 11-09-2009 12:54 PM
This is the passenger side but it is the peice you are looking at, It's boxed and double walled for strength.
http://forums.pelicanparts.com/uploa...1257799955.jpg
The paint, gavanizing, and undercoating is probably thicker than the metal.
Classic 11-09-2009 12:55 PM
Most pans are 18-20
The RD pans have some problems, with the A-arm pickup points, from what i've read.
I went the S.... option. I haven't started yet but the measurements that i've taken look good.
Don't forget to order these...
http://forums.pelicanparts.com/uploa...1257799726.jpg
And you'll want some drain tubes, as these are usually gone.....
http://forums.pelicanparts.com/uploa...1257799780.jpg
Check your tow hook, as some of the pans don't come with this.....
http://forums.pelicanparts.com/uploa...1257800039.jpg
I don't know what year you're working on but if you have the washer bottle up the front, you need to salvage this from your pan, or fab something up.
Tony
dfink 11-09-2009 01:57 PM
Well the car is an 84 if that matters. I don't remember seeing any drain tubes. Never had a tow hook as those were part of the cover for the torsion tube. Does the replacement get into the curved item in the first photo. This may be easier than some as I am not putting the tank back in. I was taking it apart in prep for a 5 gal fuel cell when I found the issue.
The RD stuff is 18ga can't seem to get through to the S guys. Conflicting information available on who has the best parts other than factory original is best. Probably depends on experience and we all know the bodies are not exactly the same one to another.
burgermeister 11-09-2009 02:24 PM
+1 on the Dansk made pans & fuel tank support. I had 2 front pans (one green primer, very stingy on spot welds, generally poor quality, didnt't fit worth a crap; one plain steel, 80% heavier, from RD, wedled well, pretty poor fit) which I decided to not use, and then the third, from a fellow Pelican, galvanized (=Dansk), fit like a glove - it just slipped right into the hole, everything lined up.
Another vendor ("noitomotua" backwards) used to sell the dansk pieces, but only as a complete pan.
+many on it's an easy, albeit crappy, job. I did mine solely using this board as a reference.
sailchef 11-09-2009 03:15 PM
The panels I used in the front tub were used cut quarters from dcauto, I bought new panels for the door jamb/rocker/kidney transplant several years ago , haven't put them in yet but they are Dansk, they look and feel like well made peices. They look like they would be easier to weld. Closer to 18 gauge.
dfink 11-10-2009 01:45 PM
I went with S brand as I was told they are good pieces. Time will tell. The S brand is not Dansk. They said they have them made locally. I got the suspension pan, the tank/battery support, the two curved supports for the suspension area, and two drain tubes which I still have no clue where they go.
500_19B 11-10-2009 03:22 PM
That is very unusual, as the S employee I spoke to in the spring very specifically explained to me that they were from Dansk, who bought the Porsche tooling...
However, if the sheet metal you get is the same as what they sent me, you won't be disappointed.
Kinda makes me wonder though... how many sets of tooling would there exist for these parts?
burgermeister 11-10-2009 04:22 PM
It's (the pan) a pretty simple part - looks like a single hit. A soft tool would probably be $50K or less in the US, probably much less in China. Skip the die development phase alltogether and accept a crappier fit with bigger radii, and "dongfeng coachworks" could probably bang out a few thousand parts for $30 a pop...
Based on the fit & appearance of the 3 different pans I had, I'd say there are at least 3 sets of tools.
From what I understand, the heavier gage galvanized parts are Dansk stampings. The green primer stuff with 3 spotwelds where 12 belong is surely made in china...
gsmith660 11-10-2009 05:35 PM
I agree that looks more chemical than rust.
Classic 11-12-2009 12:15 PM
You can see the drain holes in this photo......
http://forums.pelicanparts.com/uploa...1258056436.jpg
PET has them listed as grommet 911 025 612 00 with two fitted from MY 69
This is what they look like fitted..
http://forums.pelicanparts.com/uploa...1258056567.jpg
In the above photo the pan has three drain holes my repo only has the two as did the original, but my drain tubes just looked like grommets with little bits of rubber sticking down, so no pictures of them sorry.
Hope that helps? i don't have a PET for the latter years, but i assume they were still fitted, as even the Porsche pans have the drain holes.
Tony
500_19B 11-12-2009 12:48 PM
My car's original pan had three holes (it is an '85). Instead of the drain tubes, they used those soft circular plugs that are used in several areas of floor pan under the sills. I guess there were some of the subtle changes that happened over time.
ossiblue 11-12-2009 02:00 PM
Tony,
In the picture of the new pan, the three holes are in the lower, recessed stamped part. In the photo of the drain tubes, the tubes appear to be in front of that area--in front of the weld points for the tow hook. The picture of the pan doesn't show holes there. Is that right? Did you have to drill the holes through your new pan or am I not seeing the pictures correctly?
Classic 11-12-2009 03:05 PM
My bad i just looked at my original pan and the replacement one.
Of Note;
both have two drain holes in the channel
The original pan in the car does have two holes in front of the channel and what's left of a drain tube.
The question now is was there anything in the ones in the channel, or were they simply left open?
The repo pans are good but are missing the support that i mentioned before and also the washer bottle support, and depending on the year the tow hook.
Tony
ossiblue 11-12-2009 03:15 PM
Of Note;
Tony
Thanks.
All my early cars have the two holes in front of the recess with drain tubes in them--no drain tubes in the holes of the recess. My theory: When the gas tank support is added (sealing off the recess) it creates a small lip creating a low spot in front--the area where the tubes are located. My 73 has small plugs in the holes of the recess, but I think putting in tubes and cutting them down a bit, would allow any water that did leak under the gas tank support to drain away.
dfink 12-01-2009 06:46 AM
The usual I feel better now pictures. This has some seam sealer and black primer. I plan to try out spray on truck bed liner for protection. The actual tank hole will be filled with aluminum sheet and a fuel cell installed. But anyhow here is the mostly finish job. Not as perfect as some but the suspension bolts on easy and I don't think it will fall off.
http://forums.pelicanparts.com/uploa...1259678641.jpg
http://forums.pelicanparts.com/uploa...1259678661.jpg
http://forums.pelicanparts.com/uploa...1259678713.jpg
gsmith660 12-01-2009 09:39 AM
Looks good, dont bother with the bed liner get the wurth stoneguard and put it on there the bed liner wont stay put unless you have absolute perfect conditions I tried it.
