haycait911's Avatar
Arias 83mm piston ID help please
any help identifying these pistons would be much appreciated. these pistons were in a '69 2.0L. they are Arias, 83mm diameter, 40mm and 47mm valve pockets, rings are 1.5mm/1.5mm/4mm. the cylinders are bored birals. any info, like CR or common useage, etc. much appreciated. thanks much, Don.
Old 11-11-2009, 08:31 PM
hi,
do you know about this ARIAS brand for pistons, it's the first time I've heard about
thank you
BR
Old 11-12-2009, 08:58 AM
boba's Avatar
We used to use Arias pistons in our 2.0ltr SCCA DP 911. Ran sprint cams and forged rockers single plug, made 210hp.
They are still around,
Arias Pistons
Old 11-12-2009, 09:06 AM
3 restos WIP = psycho
kenikh's Avatar
Odd diameter - too small for 84mm cylinders, yet 2 liter cylinders supposedly can't be bored beyond 81mm safely.
They look like 9.5:1 CR.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-12-2009, 06:02 PM
haycait911's Avatar
I called Arias today. the number inside is just a casting number. the tops are custom-cut from there. this weekend I'll try to get a ballpark CR on them.
I measured the thickness of the biral sleeve on the bored cylider, it's .10"
on an unbored 2.0 biral cylinder it's .15"
Old 11-12-2009, 08:27 PM
