blau911's Avatar
How to remove powder coating from Fuchs wheels?
I have a spare 6 x15 wheel that has been powder coated by the PO. I want to redo the finish so it matches my polished wheels. Anyone know what to use or how to do it if I want to do it myself? The alternative is to send it away to have it sandblasted or media blasted, which I would prefer not to do. Anyone been there and done that?
Old 11-16-2009, 03:13 AM
a.k.a. G-man
Geronimo '74's Avatar
Powdercoating is easily removed with the search function....
ovencleaner
mediablasting
Old 11-16-2009, 03:46 AM
Powdercoating is pretty thick. I wouldn't sand blast. Way too abrasive and media blasting would take forever. The shop I bring all my powdercoating to uses good old fashion paint remover from Home Depot. I've used it myself and works like a charm.
Old 11-16-2009, 04:31 AM
nineball's Avatar
gasket remover. works like a charm.
Removing Powder Coating Quickly and Cheaply -- Chopper Surplus
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-16-2009, 05:45 AM
muck-raker
kidrock's Avatar
Blau911,
"Been There, Done That".
I did a top end job on a Harley Davidson a few years back, and the jugs (cylinders) and heads (all aluminum) were powder coated, but were done poorly (bubbling at temperature). I contacted a top-rated powder coating company to inquire about removal. Their answer?
Carb cleaner.
I took a can out and, sure enough, it removed the PC with a minimum of elbow grease. I then dipped all the parts in a tank with carb cleaner, and used a high pressure water hose to finish.
This is the biggest reason I cringe a little bit when I see powder coated engine parts.
Hope this helps.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 11-16-2009, 06:52 AM
Nine9six's Avatar
Hmmm,
Reminds me of a set of powder coated wheels on a motorcycle....I was cleaning the brake calipers with some brake cleaner, and compressed air. When I used the air to blow dry the calipers, it blew off complete sections of powder coating from the wheels.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 11-16-2009, 12:11 PM
Sleep Deprived and Grumpy
jwernquist's Avatar
I sent you a PM. Just offering to an old friend.
JW
jwernquist@wi.rr.com
262.215.6547
Old 11-16-2009, 11:02 PM
