wit61's Avatar
Alternator, Regulator, other
I have a recently discovered issue with my 1970 E in which the alternator light stays on after starting, and glows more dimly as revs increase until it finally goes out at around 3500 RPM. It comes back on as soon as revs decrease. I did not have time to troubleshoot this, but based on the symptoms would you suspect the regulator more than the alternator ? Any other ideas ?
https://www.motocron.com The Log
https://www.classicvelocity.com The Blog
Old 11-18-2009, 05:03 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Do the easy stuff first. Is the belt slipping ? Make sure it's tight. Then clean the ground straps where they connect to the body. Retest and see if the problem goes away. If it doesn't then you're into troubleshooting further. But frankly this sounds like a belt or flakey ground problem to me.
Mark Petry
Bainbridge Island, WA
81 SC
Old 11-18-2009, 05:18 PM
47silver's Avatar
test test test
When the car is off what is the voltage across the battery?
When the car is operating at idle what is the voltage?
when the car is at 3500 what is the voltage?
Without knowing some basic information it is hard to say what is wrong..
Could be:
voltage regulator, alternator, loose belt, bad ground, or loose wire.
1975 911S Targa
Silver Anniversary Edition
Old 11-18-2009, 05:19 PM
