Guest
Posts: n/a
Ok, Still in the middle of my strip-for-paint project. I need to remove the doors. I was wondering if it would be easier to remove the door pins instead of unbolting the whole hinge?
I guess my thinking is that if I just take out the pin, the door will still be aligned the same when it is reinstalled... Any suggestions? Ben.... 80SC "EURO" Coupe |
Guest
Posts: n/a
YES! You are correct sir. Tap the pins out (don't drop that door!) and you will retain your alignment.
Good Luck. Nick. ------------------ _ _ __ _ _ Nick Shumaker 1982 911SC Coupe nickshu@yahoo.com PCA -- Rocky Mtn. Region |
Guest
Posts: n/a
yes, remove the pins. alignment stays, and you don't have damaged paint around the hinge bolts. use a helper when you reinstall it so not to chip paint.
